wabaloo's Avatar
Question 911 1984 blue smoke
Hi,
I will buy a 911 1977 with a 3.2l. The owner said to me there is blue smoke when the motor is hot. what can it be and what are the possibilities of problems? It's the first time I write in a forum...let me learn from you.
Thanks, Claude
Old 04-19-2003, 12:46 PM
Senior Member
Doug Zielke's Avatar
Hi Claude,
First off, welcome to the board!
Blue smoke means oil burning. 911 motors will smoke if they are overfilled; it's a common problem. The fact that you say the motor smokes when it's hot tells me it *may* be overfilled. Do a search on the 911 Technical Forum about oil levels and learn the correct way to read the dipstick.
Be aware that some 3.2 motors suffer from worn valve guides. That will also give you smoke, usually on deceleration.
Before you buy this car, pay to have it checked it out by a qualified Porsche mechanic, or it may turn out to be a money pit.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-19-2003, 05:48 PM
wabaloo's Avatar
Thank Doug and Wayne,
I think the motor burns a lot of oil because it's a really big smoke...from behind...the car is invisible so... a lot...
Just before getting check I was thinking is was the rings...it is possible?
Old 04-20-2003, 05:37 AM
Warren Hall Student
Bobboloo's Avatar
It could be rings but that is a lot less likely than the reasons suggested above by Doug. It could just be residual oil left behind from an overfill.
The answer to Waynes' question will tell you if it's an overfill problem as opposed to worn out motor parts.
Whatever the case you need a proper inspection done to find out why it is smoking. Only then will you know the value of the car. As it is the car is worth anywhere from $3k to $11k.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-20-2003, 03:38 PM
wabaloo's Avatar
OK,
I will do a proper inspection. The problem could be oil overfill, but what are the commons problems if it's not that???
Thanks everyone!!!
Claude
Old 04-20-2003, 04:46 PM
Warren Hall Student
Bobboloo's Avatar
Valve guides.
Bobby
Old 04-20-2003, 05:19 PM
wabaloo's Avatar
Claude
Old 04-21-2003, 01:02 PM
si2t3m's Avatar
Say it's oil overfill.
Shouldn't he be able to see it visually like finding oil in the airbox (I don't know how the 3.2 vents the oil tank)? Could be a simple as that.
One thing for sure, i'd get the car checked.
Claude, Is this the car located in Granby? If you need any help regarding a local shop (not dealer) to get a PPI done in our area, let me know.
HTH
Marc-Andre
70 914-6 conversion 3.0L Webers
Marc-André
Present: 07 997.1 GT3 white, 95 993 coupe Riviera Blue, 72 911E Targa Silver, 68 912 coupe Burgundy, 67 912/911 coupe Black
Past: 98 993 C2S, 98 993 Speedster conversion, 95 993 Cab, 70 914-6 conversion 3.0L Webered
Old 04-22-2003, 01:13 PM
wabaloo's Avatar
Thanks!!
Old 04-22-2003, 03:41 PM
wabaloo's Avatar
Hi Marc-André,
You're right about Granby! did you heard about this car before! I really need some help to check this car!!
Merci
Claude
Old 04-22-2003, 05:25 PM
