-   -   air injector plug size (http://forums.pelicanparts.com/911-engine-rebuilding-forum/107347-air-injector-plug-size.html)
jhelgesen 04-21-2003 10:14 AM
Can someone give me the specs on the size plugs that go in the air injector holes on my 3.0 heads?
ChrisBennet 04-22-2003 06:59 AM
The plugs are M10x1. Link to thread on air injection plugs.
-Chris
jhelgesen 04-22-2003 08:05 AM
So, do you think these plugs at www.mcmaster.com would work?
part number 92015A155
john walker's workshop 04-22-2003 08:49 AM
the best ones are aftermarket 914 rear caliper plugs. hex head, and a flange. pelican should have them.
ChrisBennet 04-22-2003 09:04 AM
No, those are the wrong pitch (1.5). The plugs need to be 1.0 pitch.
-Chris
jhelgesen 04-22-2003 10:12 AM
Dooh, no fine thread plugs on there, I'll get them from Wayne,
Thanks Guys!
Tim Walsh 04-22-2003 11:21 AM
S caliper bleed valves are the same size. I had to order the tap to straighten out my front brakes from mcmaster.
WERK I 04-23-2003 08:30 AM
Chris,
Hey neighbor! Where is your "local metric hardware place"?
Enquiring minds want to know! :-)
Wayne 962 04-24-2003 01:48 AM
I don't think that's true - I think that the bleed valves are the same size as the plugs in the earlier heads - the 2.7s? Althought I can't recall off the top of my head, and I don't have any cross-ref on this...
-Wayne
ChrisBennet 04-24-2003 04:08 AM
I know my 993 calipers and 930 caliper bleeders and Carrera brake lines are all 10x1.0 if that helps.
-Chris
Tim Walsh 04-24-2003 07:24 AM
I do know that 10x1 is the correct size for the bleeders. I don't know the correct size of the injection plugs though.
ChrisBennet 04-24-2003 07:30 AM
I've plugged the ports in a 2.7 motor and an '81 SC motor with 10x1.0 plugs.
-Chris
http://forums.pelicanparts.com/uploa...ectionPlug.jpg
beepbeep 04-27-2003 10:52 AM
there are perfect plugs available for 1£ a pop from http://www.type-911.co.uk/
Pictures:
http://forums.pelicanparts.com/porsche-911-technical-forum/60354-stupid-guide-fitting-emmision-plugs-three-steps.html?highlight=plug
