-   -   Is this valve guide seal leak? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1073674-valve-guide-seal-leak.html)
JoeMag 09-21-2020 10:02 AM
interesting it's enough to come out at head/cylinder interface. even showing signs of that on top of cylinder.
http://forums.pelicanparts.com/uploa...1600707632.JPG
http://forums.pelicanparts.com/uploa...1600707632.jpg
Walt Fricke 09-22-2020 12:28 AM
Maybe better question is does this suggest valve guide wear? Which you can test.
JoeMag 09-22-2020 10:43 AM
Hi Walt - thx. Heads were done about 15hrs ago, so most likely not, I was actually asking because I assume it’s leaking down valve stem and it’s not oil ring on piston going bad.
