-   -   First 911 please help with compression/leak down numbers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1073814-first-911-please-help-compression-leak-down-numbers.html)
harv666 09-22-2020 04:39 PM
Looking to buy my first 911, its an 83 911sc Euro/ROW. 129,000 miles. Theres a lot of good about this car, but then theres these compression and leak down numbers and I don't know how to read them properly so I'm reaching out for help from the community. The car really hasn't been driven in the last year. This was done today. Any help is much appreciated.
compression test
#1 150psi
#2 150psi
#3 135psi - 130psi op temp
#4 145psi
#5 145psi
#6 140psi
leak down test input pressure 90psi room temp
#1 40psi
#2 60psi
#3 50psi
#4 75psi
#5 74 psi
#6 75 psi
Operating temp
#1 80psi
#2 75 psi
#3 55psi
harv666 09-22-2020 04:47 PM
I think I posted this in the wrong forum, moderator please delete. Ive reposted in the tech forum.
Jeff Alton 09-30-2020 08:19 PM
The numbers read like a tired engine. Though the leak down numbers seem high compared to the compression numbers.
Did you note where the leakage was occurring?
Has the engine been run a bit since sitting, or just fired up and tested?
