-   -   Cam removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1073842-cam-removal.html)
Lyndon302 09-22-2020 10:31 PM
Cam removal
2.0 L
Can I remove the cams by backing off the rockers.
Lyndon
dannobee 09-23-2020 08:21 AM
No.
Flat6pac 09-23-2020 08:49 AM
Pull the rockers
Bruce
Lyndon302 09-23-2020 02:04 PM
Lyndon
Emo993 09-24-2020 12:45 PM
And if your going to replace the cams you need to have the rockers reground for best results.
Lyndon302 09-24-2020 04:26 PM
Im just going to revisit my squish after a recent engine rebuild. I need to.adjust the valves and oil change. So why not pull the engine. Its just a few gaskets.I was never happy with 1.25 mm shims. Will just have to wrestle with the weight of the complete head assembly.
Lyndon
VFR750 09-24-2020 04:57 PM
Pulling off the assembled heads with cam and rockers installed is fairly common practice. Especially if you are doing the tear down for a different reason. Like checking cylinder shims.
Lyndon302 09-24-2020 05:05 PM
Also I can have look inside after my run in.
Lyndon
