Ring filing
Is it possible to file an 82.5 cast goetze oil ring to fit an 80.5 bore. Or would it end up not round or would it conform to the smaller bore.
Ive run out of options to get an oil ring for my 67s that is .5mm over size.
Or just fit std oil rings.
For reference with new oil rings.
.080" end gap with a new 80mm oil ring installed.
The bores are well used and in spec albiet at the outer limit.
Lyndon
Old 10-15-2020, 10:40 PM
Hi Lyndon,
Interesting question and probably difficult to be sure...
I could run FEA-simulation on it however a bit of over the top ;-)
Better is maybe to go a bit more experimental first.
Take an old ring and file way more then needed to make yours fit the 80.5 bore.
Then compress by hand and measure roundness and see if tendency is oval or still circular!?
just a thought....
Cheers,
Bart
Old 10-16-2020, 12:59 AM
I don’t think the gap is that important for an oil control ring. It’s just scraping oil from the cylinder and a 2mm gap would allow very little extra oil through.
Old 10-18-2020, 09:22 AM
Thats what I would like to think. It's not a race car. I have a good gap on the first and second.
Lyndon
Old 10-18-2020, 01:20 PM
Use the Light Tight test cut the gap then install the ring in a loose barrel shine a flash light from the bottom and see if it is concentric to the bore. If not don't do it.
regards
Old 10-18-2020, 04:34 PM
I was able to buy 80.5mm rings directly from Porsche. It was a while ago, call Porsche and ask for 901 103 315 50.
andy
Old 10-18-2020, 09:25 PM
Ingenieur
Yes, do this. It's all about conforming to the bore.
regards
Old 10-19-2020, 11:52 AM
Intuitively, it seems like the rings would be made to a certain tension spec which you would be exceeding by using an oversize ring and filing back to fit.
andy
Old 10-19-2020, 11:58 AM
andy
I have rang Porsche Australia and a few places in North America.
No longer available.
I have a 3 piece oil ring from a Honda B engine. 80.5 I'm looking to get the land depth taken in to accommodate these rings.
Will report back
Old 10-19-2020, 02:22 PM
Engine is in. Top ring was good as it was new and specially made.
2ring is a Honda B engine. Perfect fit. 3rd is a standard new mahle 80mm. Runs great. No smell. No smoke and goes really hard.
I'm happy
Lyndon
Old 11-05-2020, 11:05 PM
