Originally Posted by brianjames1 View Post
Great thread-
I have a 75 carerra roller in search of an engine. Thinking of buying a core 2.7
Thoughts on a newb with strong mech background doing a rebuild ?
The mag cases can be made to work, but if you don't have it already, I'd definitely get a 3.0 or later, if I were you.
Making the 2.7 mag work is a lot of work, and it'll never be as strong as a 3.0.
The reason I did mine was, that I already had the engine.
Old 11-01-2020, 01:59 AM
Originally Posted by jpnovak View Post
Your torque dip at 2100 rpm is likely too rich. your 1600/1900rpm columns have a large jump in delivered fuel. This is an artifact of tip-in fueling on take-off.
Now that you have a torque curve you need to rescale your fuel table to add an RPM column at 2200rpm. Take away (or average the 4500/5100) a higher rpm column where your torque is flat.
This will give you resolution to improve your tuning as you ramp in torque.
Also, scale your load rows to match your engines total vacuum. Shift rows to add more resolution between 85-100kPa to better match your ITBs. use a datalog to set your lowest row at MAP-min value and scale accordingly.
Thanks for your advice!
I'll get on to that asap - which is in 5 months, winter has arrived here
I was thinking of something like: 1300-1500-1800-2100-2500, where I remove 4500. 3900-5100 are fairly similar.
How how does that sound?
Old 11-01-2020, 01:02 AM
Originally Posted by winders View Post
What is the displacement of this engine? What headers did you use?
It's a 2.7 engine with 10.5 compression.
I'm using the stock '74 headers, which is the same as SSI, I think.
Old 11-01-2020, 01:03 AM
Racer
winders's Avatar
So you are saying you are getting 271 HP at the wheels from this 2.7 build?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 11-01-2020, 07:26 AM
Not at the wheels - as I understand it the dyno meassures the transmission loss when it coasts down after the run. Once it’s down to about starting speed, it subtracts the losses and you get engine hp.
Old 11-01-2020, 11:29 AM
Racer
winders's Avatar
271 HP at the crank is a little optimistic for that build especially at 7000 RPM. What correction factor did the dyno software apply?
Scott Winders
PCA GT3 #3
Old 11-01-2020, 12:37 PM
I don't have the dyno graph with me, but there is a "EOF k = -0.6%".
Other than that, I don't know.
But I tend to agree, 271HP is a lot - I was pleasently surprised
But in the end, it's just a number.
Old 11-02-2020, 04:13 AM
thanks
Ill look for a 3.0 or 3.2 many thanks
Old 11-02-2020, 01:47 PM
Congrats on your rebuild, very clean and incredible outcome. I have single TB 3.2 MS1 EFI setup on my rebuilt 3.0 but I want to go ITB and those ITBs seem to be the ticket for max flow. Can you describe the fabricating to make the filters fit the trumpets? Did you seal the plate to trumpet interface or use some sort of gasket? It looks really clean overall. -cheers
Old 11-15-2020, 08:18 AM
Hi
The filters from Pipercross came with a bottom plate with no holes.
So I made 3 holes about 8mm larger in diameter than the trumpets. Then I used sliced silicone tubes as gaskets.
I installed 4 studs from each of the ITBs to keep the plate in place.
I’ll look for a photo.
Old 11-18-2020, 02:12 PM
Pic of filter plate
Old 11-18-2020, 02:13 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Nice work. Thanks for sharing.
Henry
Old 11-23-2020, 06:02 PM
Ginger77's Avatar
Great build! I was wondering how you got the Bosch PWM idle air valve hooked up. The wires, I suppose, go to the MS as described in the manual. But how did you hook up the air hoses?
Diederick
I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname.
IG: no dedicated account but photos are posted with #ginger77
Old 03-17-2021, 07:19 AM
I’ll hook up the PC and look for in a bit 😀
Old 03-18-2021, 10:51 AM
Ginger77's Avatar
I don't think the answer is in the PC unless you're looking for photos. I literally mean how did you hook up the mechanical side of the valve? Not the electrical wires.
The idle valve blows air but into where? I get the principal with a regular injection intake boot. But I don't see how it works with us using filter or stacks.
Diederick
Old 03-19-2021, 03:58 AM
It was indeed photos I was looking for.
Basically I run a hose from each TB to a plenum, a single hose from the plenum to the idle valve and a single hose from idle valve to the right side air box.
Below are the two best photos I could find. It looks as if the hose from idle valve to air box is not fitted in the below photos.
If it doesn't make sense, I can snap some better photos for you?
Old 03-19-2021, 09:14 AM
BURN-BROS's Avatar
Outstanding build! Peak HP @7k plus should net 100hp/liter. Looks like yours is healthy. If you can figure fuel lbs/hr for your build, you can verify the Dyno results. Also, if you can get the injector quantity per cycle, that would work as well.
Old 03-19-2021, 08:59 PM
Wiring Harness
Where did you source you wiring harness
Old 03-21-2021, 03:57 PM
I made it myself 😎
Old 03-21-2021, 11:24 PM
Nice result, very impressive results.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-22-2021, 03:08 AM
