Sports Purpose 911 Driver
mjshira's Avatar
question for Wayne - from the new book
I have looked at the various engines types (set-ups) that you cover. I was wondering - if I build the 3.5 (based on a 3.2 case) what is the reliability of such an engine? does it
have the life that you mentioned a normal 911 engine having in your book? has anyone else out there built one of these and driven it on the street (not just the track)
(with proper servicing, etc.)
Old 05-02-2003, 01:03 PM
Author of "101 Projects"
Wayne 962's Avatar
The engine detailed in the book was a street engine. It's a big bore engine, with compression not too high. The twin plugs were added because the piston diameters were greater than 100mm.
These cases were built to handle the 800+ HP of the 930. The 911 Turbos easily generate in excess of 300+ HP. I don't see any major reliability problems on these engines as long as they are setup properly.
-Wayne
Old 05-02-2003, 09:24 PM
mjshira's Avatar
cool, thanks. I start putting the parts together
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 05-03-2003, 05:22 AM
Wayne 962's Avatar
On that same note, this engine *did not* run the Motronic Engine Management system. I doubt that this engine would run well with the stock 3.2 system. Well, if you twin-plug it, you can't run Motronic...
-Wayne
Old 05-03-2003, 03:40 PM
mjshira's Avatar
thanks Wayne. I have your book about 1/2 read now. I reviewed the section covering engine mgmt. systems and I understand that I'll need one. I do plan to twin plug the motor as you recommend also. The only open question remaining is what to do for fuel delivery?
Old 05-03-2003, 07:30 PM
mjshira's Avatar
That is the general view of my mechanic and shop here.
Old 05-04-2003, 08:00 AM
