-   -   head studs losing their torque on 3.3 turbo (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1076078-head-studs-losing-their-torque-3-3-turbo.html)
gumba 10-21-2020 06:47 AM
Has anyone actually tried thread locker? Either Loctite red or the sleeve 640 mentioned above?
faapgar 10-21-2020 07:12 AM
torque 38 lbs.
IMHO 38 FT.LBS is wrong for these motors.There have been some heads that the washer is collapsing the surface and the nuts loosen.A proper stud will hold its torque.Porsche engineers decided 24 lbs. was good for a very calculated reason and I know I am not smarter than them.Canyon studs work well and keep their torque.Fully threaded I have not seen any loosen.Ciao Fred
Luke M 10-21-2020 07:52 AM
I did some research on head studs for my 3.2 to 3.4 build. I can't recall which thread it was but saw where there was an issue with head nuts coming loose. I can't recall which studs they used but the main reason why I went with the Supertec studs for my build.
Do a search on Pelican that's where I found it. It was an older thread that I remember.
winders 10-21-2020 10:08 AM
Supertec has "a" solution. The 993 Turbo head studs are the solution I see all the big time high performance engine builders using....
gumba 10-21-2020 11:22 AM
ARP specs out 38ft/lb torque. Not sure whether to use the same torque spec to re- torque.
Using any type of thread locker seems like a one way ticket, and no way to re-check the torque down the road.
If I end up swapping out the head studs, I'd go 993 turbo.
outsider347 10-21-2020 11:23 AM
ARP studs
I called ARP Tech Support this AM.
I explained the situation regarding their product. He took the time to look in their call history, and found no complaints called in.
He also said that he would call their largest volume re seller,,,, EBS & spoke to Don...EBS engine builder
Don reported no problems with kits that he put into his builds.
And no complaints from customers that purchased the kit
Good enough for me!!
outsider347 10-21-2020 11:25 AM
Harold
Did you contact ARP?
winders 10-21-2020 11:44 AM
Not for me! Just based on a few queries (why in the world would I ask the company that the made the fasteners or a company that sold them?) I made when my engine was being built, it became very clear that ARP was NOT the way to go.....
outsider347 10-21-2020 12:12 PM
Well I guess that us" rookies" on this forum have to trust someone that supplies parts
ARP has been in the automotive fasteners business since the 70's. Fasteners are their only product.
They ARE the manufacture
No disrespect to Supertec, but I doubt that they do research /development /manufacturing head studs
As far as why I asked the question,,, What do you suppose Henry would say if you asked him the same question about his studs
winders 10-21-2020 12:19 PM
You buy what you want and ask questions of biased sources if you want. I ask people that actually build high output high performance engines for a living. They use parts that work or their reputations suffer...
gumba 10-21-2020 03:09 PM
What nut size does the ARP stud take, m10 x 1.25, m10 x 1.50.
gumba 10-21-2020 03:17 PM
I actually think it's an m8.
JackkTheMackk 10-21-2020 06:43 PM
I’ve read about this issue happening fairly often with ARP head studs. Steve Weiner has a comment somewhere on pelican where he kinda explains why it happens. I went with supertec head studs for my build for this very reason.
gumba 10-21-2020 07:28 PM
So did anyone come with a fix, other than tearing the motor down?
reclino 10-23-2020 02:26 PM
I contacted Peter Dawe at the start of my engine build and he said he uses Supertec head studs due to problems with the ARP ones. As I am hoping this is a one time task I took his recommendation and bought Supertec. I feel this was a safe decision based on the available information. 993 head studs are not the only solution of top engine builders.
