Partial motor rebuild 3.2, lets talk upgrades
Because speculating and day dreaming is fun!
Motor is a 86 3.2 with about 93k on it. SSI, Wong, Patrick LTV Flywheel and clutch. Bone dry no leaks in site. I dont have much history on the motor and put about 2k on it since It was swapped into my car.
After the swap I had a blue smoke issue along with other fun problems that were ironed out.
Fast forward to today. Major blue smoke is back. I’ll do a compression test this weekend and I have a leak down scheduled for next week.
I believe it’s the rings. Allowing oil to blow thru the motor.
So partial rebuild. Since the case is dry I probably won’t split the case. But do everything outside of it.
So how far do I upgrade without going crazy, gain power and not over build it so it doesn’t make sense?
I would like to retain the factory intake and ecu and have the Wong chip redone after. Anything beyond that becomes another 5k + a tuner.
Cams, P&P Heads, Pistons, P&P factory intake manifold?
Obviously this can always spiral out of control but I would like to do a reasonable upgrade without going down a rabbit hole.
Old 10-10-2020, 07:18 AM
Arlo911's Avatar
Not a lot more work to split the case and change your bearings for peace of mind. That way you can install stronger rod bolts so you can spin the 3.2 a bit higher. Add good cams. It's a slippery slope but I wouldn't stray too much from OEM, but hey, that's just my opinion.
On a 3.2 the smoke could be from bad valveguides, I think it's a known issue on them.
If you can keep your budget in check, think about adding short gear ratios or a shorter final drive, most fun per $.
Old 10-11-2020, 12:35 AM
Under the radar
Trackrash's Avatar
Bruce Anderson's "Porsche 911 Performance Handbook" has a nice section on the 3.2 including a good example of improvements with out opening the motor.
That said, I have seen a couple of guys with just an exhaust and chip upgrade looking very quick.
Gear ratios could make it next level.....
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-12-2020, 06:08 PM
My advice is to rule out anything outside of the engine causing the blue smoke, first.
Old 10-12-2020, 09:58 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Don't think there is any HP to be found in a 3.2 through internal upgrades. I would do the rod bolts. Other options are increased displacement (3.4) or a turbo.
Chris
89 Carrera
Old 10-15-2020, 11:20 AM
Luke M's Avatar
I'm currently going through this on my 3.2 to 3.4 build. I went into the lower end just for piece of mind. All of my bearings looked great but still replaced them all. I did swap out the rod bolts with some raceware bolts. It's not a cheap build but I want to play so I gotta pay..
Old 10-18-2020, 11:35 AM
