Recommended 360cc injectors...
Hey Guys - What type of injectors are people using now-a-days... I've heard from several about using InjectorDynamics ID1050X but their flow is rated at 1000+cc/min so would seem to have very low duty cycles
...I'm running MoTeC M48Pro. |
Really, the Injector Dynamics 1050x is a the way to go. It has no issues with accuracy at low pulse widths. It will work great on anything from a stock 993 to a 600 HP monster.
Injector Dynamics does not make anything smaller than the 1050x anymore...... |
Call them up. I had several great conversations with them about my engine and injector choices. I was so impressed with them I even bought there super cool fuel filter setup!
Joe,
You probably want to figure out what length you need, the type of electrical connection you want and be clear on your resistance range before doing some Googling. The Bosch online resources are good and there are a number of injector retailers who do good summaries of the various brands and models. Or do what Scott suggests and call a supplier! I wanted modern 4 hole Bosch injectors for my 3.4 converted 3.2 Motec build and ended up using these as I had them on hand already: https://www.bosch-motorsport-shop.com.au/382cc-min-ev6-injector They run around 70% duty cycle so could be a touch smaller but they work fine in practice. |
| All times are GMT -8. The time now is 07:08 PM. |
