-   -   Turbo Cam Modification Update (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1078959-turbo-cam-modification-update.html)
aturboman 11-23-2020 01:46 PM
I need to have the cam extension added on an SC cam for a turbo oil pump drive.
I have the extension piece and pump but am looking for an experienced shop to drill and tap the cam.
I know it must be perfectly centered or it will leak oil forever.
No local shops in my area will touch it so please let me know if you can recommend anyone; shipping it is easy to get a proper job.
1979-930 11-23-2020 07:50 PM
Have you called Dema Elgin of Elgin Cams? Elgincams.com
Maybe search this on the Turbo forum. I think most just run a drain back to the sump with a fitting on the drain plug.
stownsen914 11-24-2020 05:27 AM
Any of the cam grinders - Dima, Web, Dougherty, etc. - should be set up add the drive extensions to cams that didn't come with them.
aturboman 11-24-2020 07:59 AM
Thanks guys I'll reach out to them.
My sense is they'll do it if you bought cams from them but here I just bought used Genuine cams.
1979-930 11-24-2020 11:49 AM
No. Elgin will regrind or modify anything
stownsen914 11-24-2020 06:38 PM
Give them a call, but I suspect 1979-930 is correct
aturboman 11-24-2020 06:40 PM
Thanks guys will try them tomorrow
