100mm 964 cylinders on a 3.0 block
is it in any way, shape or form possible to use 100mm 964 cylinders on a 3.0 SC block (and heads)?
Cheers, Mads |
You mist use early 964 heads.cylinders. Reduce the cylinder spigot diameter. Increase the case spigot bore. Slot the holes for the head studs (different stud spacing) and run a .280" base shim. It works but it is ugly on many levels. |
wow .. that was a quick answer! thanks. :)
sigh, that was what I feared. i'm ok with a little machine work, but moving the holes for the head studs ... i'm not sure i will do this on a super good 3.0 block. But have you seen the prices for a set of 98mm mahle cylinders? used or otherwise. Wow .. and there are many 964 sets for sale out there, at a quarter of the price! so I just thought....... |
p.s. and a 95mm set for that matter.
We have moved the studs in the case before, widening the stud spacing but that was on a real RSR case where the customer wasn't willing to step up for real RSR heads. The process was easy and actually made for a better end product. That slide valve RSR engine ended up gracing the cover of Waynes first addition engine rebuild book. |
Cool!
yes, I misunderstood you. Now I have something to think about ..... :) |
If I can remember, I'll check tomorrow. Send me an email. |
Asked the same question over the 930 area some time ago:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/956306-964-cylinder-930-a.html Get some pictures about what it looks like : http://forums.pelicanparts.com/uploa...1606817949.jpg Still thinking about it :) |
I've considered it overnight.. I'm in!
If any of you have anything good lying around, I'm interested. :) And or- do any of you know this dealer? He has several sets for sale for $ 600 ....http://forums.pelicanparts.com/uploa...1606822152.jpg |
Why do this? We are going to start a fresh 3.0 build with 98mm cylinders and 4.0 RS crank. Curious why this route would be better?
Primarily because of the price!.... :):):)
I can make the modifications myself, to use the 100mm. And if the heads need to be modified, to achieve a better squeeze in collaboration with the 964 pistons, I can probably do this as well. (even though I just finished polishing them) :rolleyes: In addition, I'm curious what characteristics 70.4 X 100mm will give! |
444 Vernon Way El Cajon, CA 92020 Phone: (619)444-2290 Fax: (619)444-0394 These are the guys who get all the Singer take offs. Great guys to deal with. BTW If you're looking for early 964 cylinders sets, we have a few sets. $ 600 plus shipping works for me. |
I would seek a custom piston to maximize this modification. 70.4x100 is a cool high revving oversquare engine. They are commonly found in the likes of Formula 1 cars, two-stroke racing engines and anything else where you want to rev the engine up to produce power. They keep piston speed down which helps reliability by putting less force into things like your crankshaft and connecting rods. In general, these engines will produce more horsepower than torque and require gearing to take advantage of their top end pull. We built a 66x100 engine a few years back that saw rpm close to 9000. |
yes, I am interested in a set of 100mm up to 600 bananas. :) Or maybe a good discount if I buy two sets? :D Maybe I can make the later style recess, in the contact surface on the cylinder top end... The only thing I'm really interested in, is if they have a good "roundness" and that they have a nice surface (do not know the technical words on English)? And if I can't use the original pistons, I will have to see who makes light "race" pistons. (for human money) to my specifications. And I have to learn how 964 combustion chambers are designed. I will "work hard" to achieve the optimal squeeze!! |
But yes, I love an engine that revs free and fast! And, even though it sounds weird, I like that it does't have too much torque (TOO much) ;) This is simply because I like to use the engine fully, without it going at ridiculous speed.... And although I would like to use it on a trackday once in a while, I am NOT a race driver! And it's going to run mostly on the street! Does that make sense? :rolleyes: Something completely different, I have set myself a goal with this engine, which goes directly against what I am in the process of building. For this time I will fight hard to get the engine to go as far on the liter as possible! This might sound weird, but I simply can't help it! and tune over the top ... It's my core hobby, and my cars always get too wild for the street. (my hair is starting to turn gray) ;) and in my eyes, tuning for better fuel economy is also a kind of tuning ... :) I have already bought a WebCam 21/21 for my project, but now my engine is getting too big and rev-depending for it, I think ... Sigh But am I to use a cam with bigger overlap, then I will have serious problems reaching my goal... :confused: |
And again, simply because we can, and it's way too expensive to go out and buy! :) |
Send me an email with contact info and we'll try to work something out. Discount for quantity? of course, we've got piles of the stuff. http://forums.pelicanparts.com/uploa...1606955660.JPG http://forums.pelicanparts.com/uploa...1606955660.JPG http://forums.pelicanparts.com/uploa...1606955660.jpg http://forums.pelicanparts.com/uploa...1606955660.JPG |
I’ve been trying to decide what to do with my 3.0, This option sounds interesting, something different. Henry you said it was ugly what did you mean?
All of it is ugly. Back in the day when the 964 recall happened, the dealers had boxes of the early cylinders they were throwing away. One batch we got was 11 sets. That makes playing with these cylinders intriguing. Now, not so much. |
[QUOTE=[B]Henry Schmidt[/B];11126405]We can have the custom pistons made for you at a reasonable price.
Send me an email with contact info and we'll try to work something out. Discount for quantity? of course, we've got piles of the stuff. http://forums.pelicanparts.com/uploa...1606955660.JPG http://forums.pelicanparts.com/uploa...1606955660.JPG Wow! I obviously don't know who I am "talking" with in here! http://forums.pelicanparts.com/suppo.../gaapslaap.gif Sorry for my late reply. But now I'm finally back in my beloved "porsche world" I think it will be easier if I just send you an email! Cheers, Mads |
Henry, a little off topic but can you describe the characteristics and/or your experience with a 3.2 modified with a 80.4 mm stroke and 100mm bore. I'm also wondering if retaining the motronic efi would be adequate in a street car with say a 7,000 RPM limit. Thank you for your contributions to this forum. |
Henry I’m still debating what to do, I’m thinking maybe I should sell both of my 3.0 and get something else, but people are asking stupid money for 3.2’s et. Maybe I should give you a call I don’t know any east coast places.
The stock 3.2 injection will support very large engine with the right injectors and programing. |
You can email me with question/thoughts and we'll tease something out or you can call as well but right now my scheduling is unpredictable. |
My email is: madsracing@gmail.com (yeah yeah ... You may laugh now ... I was young when I made it!:rolleyes:) ... However, I will also try to write to you. Sincerely, mads |
Hi folks. Do you know, if this is an active mail for Henry Schmidt: supertec1@earthlink.net ? :)
Christmas vacation. We'll talk after the new year.
Cheers |
Yay ... :) Wish you, and everyone in here, a happy new year, MUCH better than 2020!
Will there be a problem with driving with the original 964 pistons, with new piston rings? I'm thinking, my plan is to drive with high compression, dual ignition, knock sensor and everything else that the 964 has. So is this not a sensible way to go?
Mine hauls ass. If you don't need to cut the case, don't. Mine came to me this way I wish it was not. It makes it a real headache if i ever have the cyls that came in it damaged and need to replace them. While its good to know I can potentially do something with 964 cyls it looks like something id rather avoid. My case was opened up to take some Mahle Motorsport cyls and pistons that are 100mm |
well whatever? I just dont think its a good idea. |
Still looking for cylinders? Send me an email and I'll give you the latest information from my parts store.
Cheers |
| All times are GMT -8. The time now is 06:43 AM. |
