964 head Stud Question
Guys,
I am putting together a motor that is twin plug. This would be my second motor I have built being twin plugged. One of the problems I have is clearance is tight between the socket/spark plug and the barrel nut that holds the head on with the existing combo. So seeking to avoid that problem on this motor I was planning on using a 964 Head stud nut. (P/N: 964 104 382 01) From what I have been able to glean from the PET Diagrams, No washer is used under these nuts. (Image Attached.) The part in question is #18 in the diagram. However I am suspect that is the case. So before I do something colossally stupid. Does anyone have any first hand info as to how this is assembled? Taking that into account if in fact a washer is not needed would that potentially change the install height of the stud into the case? Thanks for any available help http://forums.pelicanparts.com/uploa...1608706281.PNG Motor break down for people wondering because why not share, everyone likes motor specs right? The motor is a 2.8 Twin Plug 2.7 7R case fully machined Ported heads Twin plug JB Racing distributor AASCO springs and retainers 10.5:1 CP coated pistons DC60 cams 964 Oil pump Everything balanced Stock rods with ARP Hardware Headers to suit and I have a choice of 40 and 46 carbs to test. |
Performance Performance Cylinder Head Stud Kit
I'm using Henry Schmidt's Supertec Performance Cylinder Head Stud Kit, SPTC-HSK-1, in my 87 3.2L to 3.4L twin plug build.
From twin plug ignition: 12mm or 14mm spark plugs Quote:
Scott and I are refencing the same thread. |
Thanks for the links, however it does not really answer the question that I asked.
The 964 nut will probably be no help with clearance, it is pretty tall. Why not get a set of ARP 12 point head nuts and use the existing washers (or replace with ARP washer)?
964 nut will not fit early head without turning the washer part
Down a little to fit the head otherwise they are better than nut and Washer Use a plug with a 5/8 head and you won’t have issues |
Thats the only question I wanted answered here. |
I use spark plugs with 16mm, about 5/8, hex in my engines. Zero problems fitting a standard spark plug socket down in the heads.
Best "upgrade" ever, right after a high torque starter. I have no idea why someone would use the original big hex spark plugs.... |
Yes washer is part of nut
thank you for the idea. |
| All times are GMT -8. The time now is 05:35 PM. |
