-   -   2.2 S engine upgrade (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1082523-2-2-s-engine-upgrade.html)
Mart_S_1970 01-05-2021 06:18 AM
Hi,
I have just started rebuilding 2.2 S MFI engine. While pistons and cylinders have to be replaced I started thinking about upgrading the engine.
What ways can I go ? I have read somewhere that changing pistons to 2.4 S may give some extra power without need of MFI Pump resetting .
Are there any other options ?
Thank you
Martin
BURN-BROS 01-05-2021 10:27 AM
Hi Martin,
In order to get to 2.4S from a 2.2S would require a change to pistons, rods and crankshaft.
That said, the fuel maps between both of them are pretty close. I have never tried it so I can't provide feedback for actual performance.
Alternatively, you can Bore out the cylinders to 85mm for new pistons or buy Nickies with a larger Bore than 85mm
Flat6pac 01-05-2021 10:30 AM
You have a great base to work from.
Suggest 10/1 pistons on bored cylinders.
If your P&C s were good, going to a 2.4/2.7 crank and rods gives 10.3 cr
Going to 2.4 S pistons only gives you less than 8.5 cr because they are 8.5 on the long 2.4 crank.
Bruce
brother911S 01-05-2021 10:45 PM
2.2 Sengine
It is hard to beat the 2.2S engine as it is the last of the high compression engines. The 2.4 S engine was 8.5 CR to satisfy the federal laws on fuel usage. You power band will stop around 6300 rpm where as the 2.2S will pull strong up to redline.
Mart_S_1970 01-08-2021 02:52 AM
Thank you for your advice. I think I will stay with OEM spec.
Henry Schmidt 01-08-2021 03:11 PM
As cool as it is to rev the little 2.2S engine, the 2.4 with increased compression and a more modern cam (Mod S or similar) is generally quicker and much easier to drive.
Bruce
Actually, the 10.3 number theorized by changing the stroke is extremely misleading.
Over the years we've discovered that the 2.2 "S" (9.8:1) static compression is actually closer to 9.4:1. By changing the stroke the resulting static compression is closer to 9.9:1.
sebastianroher 01-08-2021 04:26 PM
There's not really much you can do to get more power out of that engine. Perhaps as other have mentioned, MOD-S cams (Dema Elgin or DRC). If you really wanted a project, you could put the MFI on the shelf and go with an EFI setup that will net you a few extra hp.
Black 993 01-09-2021 08:20 PM
Henry do you think one could run a single-plug 2.4 at 9.9:1 compression on California 91 pump gas? Maybe a little less compression just to be on the safe side? I've got a 2.2T built to S specs with the Mahle p/c's and have started thinking about using the 2.7 crank/rods and a modern cam like Mod-S for a power upgrade. Probably wouldn't go there if it meant having to twin plug it though. Thanks for any guidance.
Henry Schmidt 01-10-2021 09:01 AM
9.9 on Cali street gas is marginal as a single plug. The issue is heat. If the heads get hot, it will detonate unless ignition timing is severely restricted.
Rich mixture, retarded timing and easy throttle trough maximum torque can mitigate the issue.
Edit: sometimes you can mitigate detonation by simply changing to a cooler spark plug.
Black 993 01-10-2021 10:11 AM
Thanks...sounds like it'd be better to just shim the cyls and knock the compression down to 9.6 or .7? Any sense of what kind of power such an engine would make with mod-s cams?
Henry Schmidt 02-23-2021 12:40 PM
With Mod"S" cams, 9.5:1 + compression and some modest porting this formula should product 180-190hp at the crank.
Our twin plug, 9.5:1, Mod "S", 2450 (70.4 x 86) with 40mm Webers have been dynoed at 180 RWHP.
Chassis dynos are dubious at best but the drivability and seat of the pants acceleration seem to quantify the numbers.
