Piston edge head clearance
Piston edge head clearance. Mine measure 0.040 with new barrels and pistons Ishtar ok
This is good . .030" is minimum and .020" doesn't work .
In the past I've machined the piston to get this clearance. I'd stick with the .040" especially with JE's which have sloppy cold tolerances.
| All times are GMT -8. The time now is 11:40 AM. |
