964 Tiptronic Removal - Assistance Please
I tried searching but could not find the answer.
A friend has asked me to work on his 964 but it's a tiptronic and I'm not sure what to expect when trying to separate the transmission from the motor. Also, are any special tools required? Happy for some links to threads explaining. Any books or other resources I should acquire? thank you Mike |
Anyone?
Take the starter out and remove the 8 bolts holding the torque converter to the flexplate/flywheel.
There isn't anyone near me I can ask for assistance. Also, I have read some say to remove the heat exchangers before removing the engtrans, so I can undo a bolt at the bottom centre? If I have the engine on a hydraulic table, will I be able to access this bolt negating the need to remove the exhaust while it's on the car? |
