906 Camshaft
I am rebuilding my engine in the UK at the moment and struggling to find the torque value for my 906 centre lube cams . I have found the intake valve overlap which is (6.7-6.9) The nut in question is a 41mm .
Any help would be appreciated thanks .
Richard
Old 01-22-2021, 05:09 AM
I thought it was 42 on the nut as it fine thread.
I would lube threads and torque to 75/80 ft#
I recall we sent something out to supertec to have them plug. Cams were actually for RSR
Bruce
Old 01-22-2021, 04:58 PM
906 cam nut
I have the factory tool for that. I will check the size tomorrow and post.Ciao Fred
Old 01-22-2021, 05:13 PM
I am away with the forces at the moment and should be back mid March . I seem to recollect that when i got the tool fabricated for the removal it was 41mm .... shouldn't make much difference to the end torque though . I do remember that it was on very tight ... too tight in my imagination and required heat to remove .
Thanks for responding :-)
Rich
Old 01-23-2021, 02:07 AM
Remember, cams are castings and will break.
Bruce
Old 01-23-2021, 11:41 AM
Thanks Bruce .. i will be taking your advice on the cams .
Cheers Richard
Old 01-27-2021, 09:11 AM
