-   -   1986 Cabriolet hose diagrams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1084707-1986-cabriolet-hose-diagrams.html)
roydog 01-30-2021 07:35 AM
I have rebuilt the 3.2L engine in my 1986 911 Cabriolet. The engine is in the car and I am up to hooking up the emission and vacuum hoses. There are a couple hoses I can not see where they go, the large vacuum hose for the speed control and another hose, 3/8 diameter about 15 inches long with a few molded bends which is open on both ends. I cannot find a diagram for hose routing in the Bently service manual or the engine rebuild books. Is there anywhere I could get a diagram showing the hose routing?
Roydog
HaroldMHedge 01-31-2021 08:16 AM
The engine lid should have the Vehicle Emission Control Information label. This is from my 87.
http://forums.pelicanparts.com/uploa...1612109695.jpg
The following 86 PET Illustrations have the vacuum line routing.
107-00 L-Jetronic I
107-05 L-Jetronic II
107-10 L-Jetronic III
907-00 Cruise Control
For the cruise (speed) control, I believe the large hose vents to atmosphere and the smaller one connects to a "T" by the brake vacuum booster line. See Cruise Control Vacuum Line.
I think the other hose you are describing is 930-207-236-00 item 28 on Illustration 107-00. It runs between the throttle body and air valve.
roydog 01-31-2021 03:56 PM
Thanks Harold
