-   -   Pin placement question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/108515-pin-placement-question.html)
farleyd 04-29-2003 06:49 AM
I am a bit puzzled about the pin placement. Ive read somewhere that pin placement is an issue when going from 2.2 to 2.4? Is it related to the different lenght of rods/crank of the 2.2 vs 2.4? Are the pistons physically the same
apart from comp ratio? Id assume so, as Wayne suggests in his book to put 2.2S pistons into a 2.4S case, making it way better than 2.4S.
Am i finally getting something right????
- A complete novice still puzzled by that simple 911 rebuild operation.....
Wayne 962 05-02-2003 09:30 PM
The rods are different between the two engines, and as a result, the wrist pin holes in the pistons changed. This is because the deck height needs to be the same for the pistons. I can't recall which pistons are closer to the edge, and I don't have a set available here to check...
-Wayne
