-   -   2.2S+ Webers jettings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/108603-2-2s-webers-jettings.html)
farleyd 04-29-2003 05:19 PM
Hi to all, i have a set of 85mm (2.2) 10.5:1 comp ratio pistons that ill be fitting into bored to 85mm Biral 2.2E sleeves along S-cams, Webers and 914/6 headers.
My questions are:
1) main jets?
2) idle jets?
3) venturies?
4) emulsion?
5) What specs vs stock 9.8:1 MFI 2.2S?
6) Who sells that stuff? PMO?
Thanks!
jluetjen 04-30-2003 04:23 AM
Here's a thread that has a whole lot of information on the affects of different jetting on a number of configurations, some of which are similar to what you are describing.
keitho64 06-06-2003 06:29 AM
Your setup sounds very similiar to mine. Check out this thread
http://forums.pelicanparts.com/porsche-911-technical-forum/110785-approaching-zen-2-2t-s-carb-tuning-question.html#post831811
Here is the main info:
I have Weber’s with:
1) main jets? 130 at first but now 125 and this was an improvement.
2) idle jets? 60 now. I tried 65 but they were to rich.
3) venturies? 30mm now but I plan to try 32's soon
4) emulsion? f1
5) What specs vs stock 9.8:1 MFI 2.2S? cannot give any specifics at this time. I plan to put the car on a dyno in the next month or twol
6) Who sells that stuff? PMO? PMO or Pierce Manifolds.
I am running Nippondenso W24ESR-U plugs. The motor is a 2.2T with S pistons (I think), S cams, and ported T heads.
Let me know what you end up settling on for jetting. I would like to compare notes.
Wayne 962 06-06-2003 12:36 PM
You're running a twin-plug system, right? Otherwise, you will probably have trouble...
-Wayne
TimT 06-06-2003 05:36 PM
Im wondering that without twin plugs. What makes this set up a problem?
keitho64 06-06-2003 06:05 PM
I am curious as well. I do not have a twin plug motor either and it seems to run ok. Is the twin plug required when you are higher than stock compression like the 10.5/1 listed in the beginning of this post?
Wayne 962 06-06-2003 11:03 PM
Anything over 10:1 should be twin plugged, otherwise you may have detonation...
-Wayne
jluetjen 06-07-2003 09:35 AM
Wayne, I think that a single plug and >10:1 CR can work, but you MUST use 100+ octane race fuel. This leads me to another question I'll put on another thread...
