Is this a bad cylinder gasket?
Hi
I have a 2.4T engine with 2.2S pistons.
There was some oil leaking and I decided to rebuild the engine.
I see the top of the cylinder inner ring is really sooty and the cylinder head sealing ring is totally broke ( the spring is coming out hundreds of pieces)
Old 02-21-2021, 10:47 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Victor-Reintz make some pretty low quality CE rings and in the 84mm size they were too thick. This additional thickness prevented a proper head to cylinder seal.
The cylinder actually seals metal to metal with the gasket more of an oil seal than a compression.
If the cylinder to head is not metal to metal, the head stability will be compromised.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-21-2021, 11:20 AM
Thank you for help Henry!
Is there any way to measure the head and the cylinder seat together correctly? maybe the start thickness of the CE ring?
Other question:
The engine is the follow
2.4T engine with 2.2S pistons and E camshaft. The heads are 35/33mm opened.
The car is really weak under 4000RPM, can it be the too big intake ports?
The MFI throttle underside is also opened to 35mm.
Old 02-22-2021, 04:23 AM
I tiered to measure the gap between the cylinder and the head
Old 02-23-2021, 07:28 AM
Other question:
Your issue could be a number of things.
Too little cam for the compression is one thought.
MFI tuning (generally too rich) is another.
Ignition timing still another. I find that these little MFI engines love timing. Although the higher compression (9.8:1 ?) will challenge the ability to run more advance, we find they really like 34-36 degrees better than the suggested 30 degrees you might imagine for the "S" pistons.
Higher compression will want to detonate but the (always) rich mixture of the MFI
mitigate some of the compression effect.
Henry Schmidt
Ph: 760-728-3062
Old 02-23-2021, 07:39 AM
It's a 914 ...
stownsen914's Avatar
Is that taken by torqueing down the head? It looks like .004" (.1 mm)? That's a big gap.
Old 02-23-2021, 07:45 AM
Yes the head was torqued down in 2 steps 10Nm and 32Nm
This was a Victor Reinz product, now I tiered to get Elring
Old 02-24-2021, 01:30 AM
Follow Henry's advice , do not use the V. R. CE rings , buy Porsche rings from the dealer .
Old 02-24-2021, 07:03 PM
The 'spring' in the VR gasket is too strong and prevents the ring from squishing down as intended? I have VR sealing rings in my 2.4 and just finished timing the cams. I'm not excited about tearing it down if I don't have to...
Matt B
'73 911E
Old 03-01-2021, 08:43 AM
I hate to tell you , but I would if it was me . V. R,'s do not fully compress in my experience . The combustion gases and heat will soon deteriorate the C E rings because of the space remaining between the cylinder head and cylinder .
Old 03-01-2021, 06:32 PM
kwikt 911's Avatar
What cylinders are you using. Reason I ask is because there is a set 84mm aftermarket that had a shallow head gasket groove. When tightening the head it would crush the gasket to pieces then head would leak.
Old Yesterday, 03:42 PM
OEM heads and barrels from 1973.
Matt B
'73 911E
Old Yesterday, 10:51 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
