Tiny chip at the top of liner
Gentleman, thoughts on the inner top corner chip in this liner? Pulled the heads to address a concern at a different cylinder and found this, no doubt from detonation. Leak down on this cylinder was 4%. Outer area looks fine of course
http://forums.pelicanparts.com/uploa...1613933477.jpg |
I think I'd source another cylinder.
Am I seeing things or does one cylinder have a CE ring and the damaged cylinder does not? They look like two different types of cylinders. If both have CE rings, the damaged one is definitely knackered. |
Yup. Both have CE rings. No idea where the cylinders came from as it’s not my build, rather just a local racer needing work on the thing. Strange it shows suck little leakage at 100psi, of course that could be amplified at combustion temps/high psi.
| All times are GMT -8. The time now is 07:52 PM. |
