-   -   3.2 clutch ID (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1087040-3-2-clutch-id.html)
mepstein 02-25-2021 04:31 PM
3.2 clutch ID
How do I identify a clutch and pressure plate for a 3.2 engine with a 915 trans?
Flat6pac 02-25-2021 04:54 PM
The clutch TOB will be for the finger engagement .
The 915 is a smaller clutch disc than the g50
The clutch pack is the same from 72 to 86
The G50 TOB fingers install horizontally and is the same size as the turbo clutch
Make sure you have 915 splines on the clutch, not 911 or 925 splines
Bruce
mepstein 02-25-2021 06:15 PM
Bruce
Thanks Bruce. That helps a lot. I have a pile of used clutches and pressure plates to choose from. Used but free. I just need to find one that works.
