-   -   Would Someone Please ID This? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1087434-would-someone-please-id.html)
Jagshund 03-02-2021 10:02 AM
Found in strainer of '72 2,4 engine. Measures ~20mm outer ~12mm inner. The missing piece is accounted for.
http://forums.pelicanparts.com/uploa...1614708097.jpg
Jagshund 03-02-2021 04:15 PM
Really? Nobody? So I have phantom parts floating around inside the case. Considering the source, it's not too surprising.
Henry Schmidt 03-02-2021 04:47 PM
Distributor washer. Goes between the gear and housing.
http://forums.pelicanparts.com/uploa...1614732828.jpg
Jagshund 03-02-2021 05:33 PM
Thank you, Henry. I needed that.
