It seems your accusations of nefarious intent says more about your character than mine. I don't need more sales. I'm an engine builder not a stud manufacturer. I had the stud designed because nothing on the market fit our standards. I hesitate to engage in these threads because my stud orders go through the roof and I can't handle the orders we already have. Even the mill is having a hard time supplying our material. Right now we have back orders for all the material from the next shipment from the mill. |
Your idea that only people who build engines have access to knowledge about head studs is stupid. It's also stupid of you to ignore the fact that guys with great reputations for building high performance Porsche air-cooled engines don't agree with you regarding the 993 Twin Turbo head studs. Promote your head studs anyway you want and the forum allows. But stop bashing head studs that clearly work well and are used all the time by top level engine architects and builders. |
on a race engine with around 30-40 hours, does one reuse the dilvar studs? or is it best to replace with a refresh?
Porsche got smart and started using higher strength steel studs. Still the ridiculous all-thread but not Dilivar. I'm not sure if they life the studs or not. My guess is, no. |
nope asking about the race engine that winders architect built.
http://forums.pelicanparts.com/uploa...1615240333.png |
Yea, I know... I've bought a few sets from henry over the years for all my builds... I was just trying to get a feel for winders thoughts on longevity. everyone has an opinion, but it seems that his is the only one that is correct.
How many 400+ HP rebuilds can you get out of a 3.6L case? |
My only point has been that the 993 Twin Turbo head studs are not the crap that Henry makes them out to be. They are used by most if not all of the big time high output engine builders. They are a viable option and the preferred option of many. I am not trying to stop anyone from buying Henry's studs. I am try to stop Henry from bashing studs that clearly work well regardless of what he says. I am sure the SuperTec head studs will work great and that you will be quite happy with them. Why not? You have used them before. My research led me down a different path. Is Henry's opinion the only right one here? I hope you would say no because of course it is not.... |
So no, I won't stop giving them the best information I have based on decades of experience. I will offer my opinion, offer the reasons for my conclusions and respond to questions both common (often wrong) knowledge and the somewhat obscure. I will continue to bring innovation to the table and thwart misconceptions and misinformation whenever it invades the conversation. |
The 993 all thread is $1200 for 24 !!
Supertec is $725 and that includes nuts and washers. I'm not an expert, but I have the Supertec in my two engines and they haven't broken like the diavar did they replaced or leaked as the steel ones did. They aren't 10.000rpm 1000+hp engines, just slightly hot modified street/track engines. There might be other studs that perform equally well, but for 725 they are a bargain while the 993 are a rip off! I would buy again if I build another engine. Sorry for the endorsement Henry. ;) |
Not much. If you check 100 different builders and you will get 100 different ways to build an engine. Most builders do tend to stick with what has worked for them in the past. |
What does it prove? It proves the 993 Twin Turbo head studs work and work well. If they didn’t work they wouldn’t use them. If they didn’t work, why would they use them and spend so much a crap product? Because they are all idiots? Not likely... |
In the beginning there was a rock and a chisel.....all the experts used them to write.
Even God wrote on rock tablets. Then came the pencil and paper.......OMG were all the chisel and rock guys idiots..... Nope...they just used what they knew. |
Ah, I see. They don’t know any better because they never keep an eye out for something better.
Except these are the builders that are still pushing the envelope and not just building the same old engines from 40 plus years ago..... |
I'm not saying they don't know anything, I'm saying you don't know anything and you don't speak for the consensus. You just parrot your own beliefs. |
