Tensioner Rebuild
Hello, my mechanic tells me that the chain tensioners in my 1968 2.0 engine is not rebuildable because it has the thick flange. Is this true? I don't want to do Carrera tensioner upgrade as I wish to retain my 1968 engine as original as possible as well. I look forward to your responses. Thanks very much!
Old 03-16-2021, 08:46 AM
Martinlassmann's Avatar
Tensioner
Take the later one, which you can easy rebuild. Installation with savers and it works for a long time.
Martin
Old 03-16-2021, 09:06 AM
Martin
Sorry I don't know what you mean...
Old 03-16-2021, 10:03 AM
targa72e's Avatar
If you do not want to go with the Carrera tensioner then the general recommendation is to use the later 930 tensioner 930 105 501 0R
Along with the protective stops (or locks) that keep the tensioner from collapsing completely in the event of failure.
It is also generally recommended to upgrade to the later Idler arms that have a bushing and a wider mount.
john
Old 03-16-2021, 12:22 PM
Thank you John but where do I buy a pair of this tensioner 930 105 501 0R and the applicable idler arms as I can't seem to locate any but used ones. Cheers.
Old 03-16-2021, 07:31 PM
Could someone please post the part number for the recommended 'later idler arm' suitable for the 930 tensioner 930 105 501 0R that I want to install. I have searched both Pelican and Stoddard to no avail. Thank you very much.
Old 03-17-2021, 05:15 PM
https://www.pelicanparts.com/More_Info/PELREBKT17N.htm?pn=PEL-REBKT-17N&bt=Y&fs=0&SVSVSI=5867
Henry can convert your regular arms to wide, another option.
- andy
Old 03-17-2021, 10:46 PM
- andy
Thank you very much Andy! Yikes, is the Henry alternative cheaper? Who is Henry
Old 03-18-2021, 08:57 AM
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-18-2021, 09:03 AM
Thank you!
Old 03-18-2021, 09:50 AM
Chain idler arms
andy
Old 03-18-2021, 11:33 AM
Thank you very much for you help!
Old 03-18-2021, 02:55 PM
One more thing : Newer idler sprockets with bushings . I had one seize once , not good , engine stopped and was a project to repair .
Old 03-21-2021, 07:44 PM
Thanks Richey!
Old 03-22-2021, 04:03 AM
911 tweaks's Avatar
might want to consider the smart racing tensioner piston stop/shim solution.....
I live for 911 tweaks...
Old 03-22-2021, 10:07 AM
