Dude, did you read what I wrote? I said there are more builders with many more hours of experience using 993 Twin Turbo Dilivar head studs than there are using Supertec studs. That is the empirical data I am talking about. You are the one that wanted to play the empirical data with years of experience game and I happy to do so. I was referencing usage rather than ovality.
Winders,
Why do you feel the need to change someone's opinion on this topic? Your opinion is yours, your welcome to have it. But returning to this effort of defending your opinion over, and over with such conviction just makes me ask WHY. |
In a thread dedicated to the question "why close a thread" some people can't help but illustrate why.
This thread is not about head studs. It's about the need for a moderator to step in. boyt911sc nailed it. Obsession........... In an earlier "head stud" thread, Winders touted Aaron Burnham as an expert that used Dilivar in his builds....Now that Aaron is challenging the "religion of Dilivar", Winders can't help but "call him out". Obsession "to be right" mixed with a healthy dose of "but what about the cool kids" Here's a little heads up: Aaron has a great wealth of actual knowledge/experience that he is willing to share. Challenges from the "clueless, let's silence dissent crowd" is destined to chase him away. To the asshat who questioned whether he's an engine builder: Aaron builds great engines....I've watched him do it. Come after me, I like winding the top and watching it spin into the ground. |
Can we hear more about the "Marginally reduced failure rate"?
"...reinvented the Dilivar. This time with an all thread monstrosity that offered a slightly more aggressive clamping force and marginally reduced failure rate." |
Also what is the best lube to use on through bolt o-rings? http://forums.pelicanparts.com/support/smileys/wat5.gif
This went down the toilet..... lol
My hope is that we can all post our opinions, and not get butt hurt by other's differing thoughts. ON EVERY TOPIC in this forum. We don't always need to be "right" 100% of the time. If we believe in our experience and the products we use we can post it. Our experience should not be called in to question. It is our experience and there is no way you could question it unless you were there gaining that very same experience over the years it took to create it. If you think you know better, put your thoughts into practice and prove that your new found experience yielded different results from your antagonist.... :) Then, we will all learn from your actual experience too. We all learn all the time, unless we always think we "know" better.... Chill out and relax about someone's experience that doesn't jive with what you "learned" online. Do some testing yourself, then you can actually form a valuable "opinion". People who always want to call others out are what ruin these forums. Again, not a single person posting has to be "right". They stop experienced people from posting and sharing thoughts that may be valuable to a first time engine builder. The most sad part of this whole $hit show is this. I am pretty sure all of the conflicted parties could sit around a table and share a few beers discussing the energy and enthusiasm they have for this passion. All would get along with only food and drink in front of them instead of a keyboard.... Cheers |
Funny. My only point all along has been that the 993 Twin Turbo heads studs are a solid viable option for those looking for head studs that work and work well. I have not negatively criticized any head studs in all of my posts. Empirical data is on my side on this one. Yet it is okay for certain people to tell me my thoughts are worth nothing since I have no experience building Porsche air-cooled engines.
Then you come on and say: Chill out and relax about someone's experience that doesn't jive with what you "learned" online. Do some testing yourself, then you can actually form a valuable "opinion". The idea that "valuable" knowledge can only be gained through experience is ludicrous. I don't need to build Porsche air-cooled engines to obtain valuable knowledge about the parts used to build those engines. I don't need to do testing. I can gain knowledge from the experience of others. Let me tell you a story: When I decided to build a high output race engine for a PCA GT3 class car, I new I needed help. I needed to find a person to design the engine for me. The information I needed to put together the kind of engine I wanted to build was not available for free on the Internet. The people that had the information I needed weren't going to just give it away. After doing a lot of asking around who would be a good choice for helping me with my engine project, William Knight's name kept coming up. Long story short, William designed the engine and sold me most of the parts for the build. I was having a person local to me actually build the engine. When head studs came up William wanted me to use 993 Twin Turbo Dilivar head studs. After reading all the terrible things said about Dilavar here on this forum, I had a problem with that recommendation. After all, all Dilivar head studs are doomed to fail, right? William insisted...and kept insisting. So, me, being a "trust but verify" kind of guy, started researching head studs. I checked with engine designers of similar caliber to William or people that had engines designed by engine designers of similar caliber to William to see what head studs they were using in engines similar to mine. What did I hear from just about everyone I talked to? They used 993 Twin Turbo Dilivar head studs. Not a soul said they used Supertec head studs. A few people said they used ARP studs and a couple people said they used "proprietary" studs and did not want to divulge where they came from. Anyway, I came away from my research project with new information from many experienced sources that did not jive with the information I had received here. There were just too many experienced engine designers/builders out there using 993 Twin Turbo Dilivar head studs and happy to do so for me to go against William's recommendation. After completing my research, using 993 Twin Turbo Dilivar head studs in my engine build ended up being a no brainer. |
Since this thread has devolved back into a head stud debate, I'd like to share an anecdotal experience of my own. This is about engine component choice in general, nothing specific.
I used to have this friend that wrenched on/restored Ducatis. He was known internationally, and guys would ship their bikes to him for service. One day I was out at his place while he was building a hot rod 900SS motor. This was back in the 90's. so my recollection is spotty... Anyway, I recall asking him why he wasn't using the latest widget I had read about in his build. I design engines for GM, and at the time I was in the Advanced Design group. It was my job to invent things, remove mass, push envelopes, all in the name of improved performance, increased durability, and/or cost reduction. I couldn't understand why Gregg would leave potential performance gains on the table. And then the penny dropped... At my job, I had engineering and analytical support. Lots of it. More importantly, I wasn't writing the cheques. Like any really good mechanic, Gregg stood by work. If he built an engine that failed, he ate it. The point is: why would he -or any other engine builder- take on the risk of an experimental component? Maybe that widget would have yielded an extra couple of horsepower. So what? Unless the client's name was Casey Stoner, he wasn't going to be able to use that additional power. That's not to say that Gregg wouldn't eventually use said widget. He just wouldn't do so until there was enough data in the community to support it. As for 993 head studs, I have to disagree with Henry. I would call a fully threaded head stud an abomination. And I'd bet next month's pay cheque that there was no engineer at Porsche pounding his fist on the table hollering, "We MUST use a fully threaded stud, because it's BETTER!!!" That conversation much more likely went, "Yah, I know it's ugly, but it meets our Bill of Design... And it'll save us six bucks an engine." |
And I'd like to add that I have a huge amount of respect for anyone willing to take on the task of developing and manufacturing ANY component with the goal of improving these engines. It's a high risk endeavor, and I doubt there's any real money in it. Those that do it can almost only be doing so out of passion.
You also postulate that the Dilivar stud had a financial component. I believe that financial component was a warranty issue but there you go. The all thread design also had a structural component. Not performance but survival. As noted in decades of Dilivar failures, the material is susceptible to environmental influences. Dilivar corrodes and fractures under stress. Instead of using a corrosion resistant material they chose to mitigate the environmental effects with coatings and surface forging created by thread rolling. As for the testing component: We tested our studs in both racing and high mileage street application for 5-6 years before offering any sales to the general public. Let's review. A clean-sheet stud design that makes sense (ease of assembly, more consistent torquing numbers, using the highest quality, fine thread, 12 point nut), using a material that resists environmental influences and offers a clamping force more in line with the engine designers original intent. Hmmmm, where would you find such a stud? |
My "disagreement" with you, Henry, was entirely tongue in cheek, but I think you know that...
I am, incidentally, about to undertake my own 3.0 engine rebuild. I just need to get a few last minute ducks in a row in the garage before getting stuck in. I'll be using your head studs, but I'd also like to chat with you about your 3.1 option if you're still offering it... |
http://forums.pelicanparts.com/911-engine-rebuilding-forum/1087450-cylinder-head-clamping-bore-distortion.html [QUOTE=You also postulate that the Dilivar stud had a financial component. I believe that financial component was a warranty issue but there you go. The all thread design also had a structural component. Not performance but survival. As noted in decades of Dilivar failures, the material is susceptible to environmental influences. Dilivar corrodes and fractures under stress. Instead of using a corrosion resistant material they chose to mitigate the environmental effects with coatings and surface forging created by thread rolling.[/QUOTE] I believe the choice is to allow excessive clamping force to distort your cylinder bores, or to find a solution to that problem, and then solve the stress corrosion issue associated with it. Porsche did the later. You do the former. [QUOTE=As for the testing component: We tested our studs in both racing and high mileage street application for 5-6 years before offering any sales to the general public. [/QUOTE] Maybe so, but Dilavar has won Lemans outright on 15+ occasions. I think I'm going with Dr Metzger on this one. https://christophorus.porsche.com/en/2019/390/le-mans-1970-hans-mezger-17083.html [QUOTE=Let's review. A clean-sheet stud design that makes sense (ease of assembly, more consistent torquing numbers, using the highest quality, fine thread, 12 point nut), using a material that resists environmental influences and offers a clamping force more in line with the engine designers original intent. Hmmmm, where would you find such a stud?[/QUOTE] Why would you want to find such a stud when a superior alternative that doesn't produce excessive clamping forces on thin aluminum cylinders exists? Finally, it's DILAVAR Henry, not DILIVAR. |
Scott, I did not say that valuable knowledge can be only gained through experience. You are putting words in my mouth. I said actual experience should not be discounted. It is experience, after all. The same way you do not want the experience of the people you talked/emailed with discounted. It is their experience, after all.
Relax, it is not a contest.... No one has to be right. We are all trying to relay our experiences. Relay yours, and if that is research, so be it, as that is valuable too. Then let the reader learn and make a choice.... You don't always need to tell people they are wrong about what their experience has taught them because you know of contradictory opinions/experience. I really don't care if people agree with the thoughts/tips/advice I post. I post it, if it is valuable to one person or no one, its all good by me. I suspect you won't listen, but, please, continue to post what you have learned. It is valuable and trustworthy. And then leave it at that. It will make what you post more appealing to the readers. If you want your opinion to be heard and valued it would help... A forum is most valuable when many points of view are expressed. It gets devalued when it always turns into a bun fight. Its like trying to win a DE.... No trophies here and no pretty girls to kiss on the podium..... Cheers |
Jeff,
I am not putting words in your mouth. You wrote: Do some testing yourself, then you can actually form a valuable "opinion". That sentence is pretty clear. If I don't actual test something myself, I can't form a valuable opinion. That means without experience my opinions, based on the knowledge I have, are not valuable. So, if that is not what you meant to say, be more careful with your words. As far as this head stud things is concerned, I mention 993 Twin Turbo heads studs as studs that work and work well. Henry says they suck. I say they don't and he says they do. I back it up saying where I got my "knowledge" and Henry says I am some disciple listening to the "cool kids" and because I have never built an Porsche engine my posts mean nothing. Yeah, I am going to keep quiet after that crap..... |
Scott, an opinion formed on experience is different from research. You are relaying what others think. Which is fine, you have access to them at more frequent rate it would seem than the rest of the forum members have. But it is their opinion.... You may agree with them, and that is all good.
Surely, you can understand that. You said "Yeah, I am going to keep quiet after that crap" lol. That is because you still think it is a competition. Why? You have a nice racecar, have likely achieved success in some other walk of life to be able to afford it, so relax. There is nothing to prove here. You don't seem like a silver spoon sort of guy, so you have nothing to prove here. Post your thoughts and opinions, refrain from the constant arguments that you have to prove someone else is wrong..... Scott, the intelligent people who read the forums can separate the BS from the fact. You don't need to spoon feed them all the time to prove that YOU THINK YOU ARE RIGHT. But, it is pretty clear you have no value for any opinion that differs from yours. And, because you have to win, you must call out that opinion and make a big fuss. Like I said, the people who are actually going to gain from the posts, regardless of the position/opinion, will see through the playground infighting and make an informed choice. It doesn't matter if it what you think is best. Like I expressed in the past, I have ZERO F$CK$ to give if people don't take my advice/thoughts. It really doesn't hurt me. What bother's me is certain people who continually destroy forum posts because they always need to win or be right. It is a community, respect the fact that we can be members of a passionate community, like most of the others do. Thank you for your technical contributions to the forum. People may, or may not, value them less because of your approach. If they value them less because of your tone and delivery, posting them becomes a waste of your time as a contributor to the Community. But if doing so, makes you feel good, continue on... Cheers |
Moderator.......
This thread is getting worse than the other thread you CLOSED. Time for a cool down. Tony |
Don’t we have a PARF section?
I guess by this answer, you believe that Porsche engineers never make mistakes? You think the 2.8/3.0 RSR engine was the same as the engine offered to the public.? You think the RSR used magnesium cases? You think the heads were the same as a 2.7 or 3.0? You think the cranks were the same? Do you believe that the later 74.4 cranks offered to the consumer was a "great" crank and rod design? No room for improvement? Do you believe that ARP bolts are a major improvement over Porsche rod bolts in these engines? Do you believe that the cranks in Porsche race cars ever use the 55mm rod journal found in production cars? How do you feel about the rod length to stroke ratio offered in production 911 engines. In most Porsche engines, it sucks. Most people who understand these basic concepts understand that engines are built with compromises....even Porsches. As these flaws start to materialize, innovative engine builders seek to push the envelope with design improvements. Tensioner arms, rockers, rod to stroke ratios, head studs, rod bolts, compression ratios, cam profiles all deviate from the long held production precepts to produce a longer lived and much improved platform for the Porsche driving experience. |
| All times are GMT -8. The time now is 08:47 AM. |
