Cheaper Digital Bore Gage?
I'm looking for something on the cheaper end. I found these two and have a T bore gauge set to double check.. Or is the T bore gauges good enough. I am working on an 80 911 and then at some point will use these on the 81. So it is really just for a couple uses.
https://www.amazon.com/Accusize-Tools-0-0005-Digital-EE20-5274/dp/B00IGELLRI/ ![]() https://www.amazon.com/Anytime-Tools-Electronic-Precision-Resolution/dp/B000XYND0M/
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Easily Confused
I have the Anytime Tools unit and it seems to work very well for the $$.
The last digit has an accuracy of +/- 5. I looked at the telescoping bore gauge set but didn't like having two measurements that could induce error. One measurement is actually measuring the bore with the "T", then you have to measure the "T" with a micrometer. This is a good way to get stackup error. As with any bore gauge, the cal/setup is tricky. I invested in a used ring gauge off ebay and double-checked the setting with a vernier micrometer.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 Last edited by dtxscott; 03-25-2021 at 08:03 AM.. |
It's a 914 ...
When it comes to high precision tools, my attitude is buy a good one or it may not be worth the $$ (or possible inaccurate/imprecise measurements you'll get from it). Maybe the one noted above is good, not sure. I bought a used Mitutoyo for like $150 and had it calibrated.
This type of bore mic usually offers .002" accuracy . repeatable measurements are key.
I spent $700 on a Sunnen dial type , used , to the .ooo1" Always repeatable . Pay now or pay later , off by .002" can seize a piston . Resolution is not the same as accuracy. Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 03-25-2021 at 03:37 PM.. |
abit off center
the key is all in the setup, get a good set of gauge blocks or setup ring or you will just be guessing
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
hey ian... r u still playing out in the sw desert...? hope all is good...
ps add to your team mark burkit...))
I live for 911 tweaks... |
It's a 914 ...
The ad says it's accurate to .0005". Not bad, but .0001" would be better depending on what you're doing.
Ingenieur
You can simply remove the cheap dial gauge and swap it out for one that reads down to .001.
T bore gauge not accurate.
The first one you showed reads to half a thou (if I read it correctly) or based on the picture, the second one to another decimal point.... The second one would be my choice between the two. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 04-06-2021 at 08:46 PM.. |
