Somehow "Autocad" & "world class engineers, like myself. " don't go together. . . .unless you mean you're a "world class engineer" mapping sewage and water run-off.
Yeh, Right |
Snowjob,
You obviously have either a short-term memory, or cannot read. If you look at my response to the original post I said: "I don't know the specific maching steps that Walt uses to ensure that these are in there tight..." Unlike you, who seems to make wild guesses about what *might* work, I actually admitted my lack of knowledge on this subject. In a followup post, I suggested that the poster contact Walt and investigate further. In contrast, your followup posts were filled with conjecture and rude remarks. -Wayne |
Oh, and Island - we used to use AutoCAD to design and build miltary communications satellites at Hughes Space and Communications. The latest parametric versions easily rival ProE and CADDS 5. I was chair of the committee (for a while) to integrate AutoDesk's Mechanical Desktop as a lower-cost platform for 3D modelling of electronic units.
-Wayne |
It's funny, without all the name calling and chest pounding, this thread would have been a lot shorter. Something along the lines of...
1) Does anyone know the technical specifics for installing case squirters? 2) No, but it can be risky to the novice. 3) Who might? 4) Check with Walt, etc... 5) What machine and or approach would you use? 6) Bridgeport (not a hand drill), 2 axis, 6 axis, etc. 7) Don't forget the ecomonics of the make vs. buy decision. It would also be neat to ensure future supply of the skill. 8) Great! I'll post what I learn since I seem to be going into unknown territory for this BBS. (Note; the frontiers of this BBS's knowlege are pushed forward a little more! SmileWavy ) BTW - I think that this is about the shortest post that I've ever submitted. You guys always pull the best from me! |
help! can't shut off the snowblower! it just ate my dog, and it's headed toward my 911! run for your lives!
LOL, John!!
I've been waiting for the weather to get warmer.... ;) |
I suppose if you're just modeling planer & ruled surface curves, something like MDT(Mechanical Desktop) will do. But to say "The latest parametric versions easily rival ProE" is like saying 'a hand drill can do the same thing as a CNC-mill' ;) I'm not saying sound engineering can't be done with Acad products. . . .lots of great engineering has been done on the proverbial napkin afterall. It's just when I read someone claiming to be a "world class engineer" supporting their claim by touting Autocad . . well, just check out http://usa.autodesk.com this is what autodesk is about . .. "making the grade" in a 2.5-d world. (BTW, MDT was dropped a while back) http://forums.pelicanparts.com/uploads/00Adesk.jpg |
Well, this thread has sure been all over the map and I am just trying to get information on installing Squirters.
I thought I would throw in my 2 cents on CAD systems since I have been a user since '88 and selling them since '96 including full 5-axis CAM systems. Anyone know what primary 3D CAD system Porsche uses? Ferrari? Daimler Chrysler, VW, Audi, Peugeot, Mitsubushi, Fiat, Hundai?? How about Lockheed Martin on the F22 & Joint Strike fighter? Boeing, Cessna, Raytheon, Gulf Stream, Sikorski, Bell Helicopter? They all use the same system!! I'll give you a hint: It's not Autocad, Mechanical Desk top, or Inventor. It's not Pro E, Unigraphics, Solid Works, Solid Edge, Think 3, Cad Key, Visio or CADDS 5 (note I said "Primary 3D CAD system" as all of these co's are what I call multi-CAD). I'll mail a free Join Strike Fighter T-shirt to the first correct answer. JB |
CATIA??? :D
Yeah, it would be Catia. You can add Honda to the list too.
Definitely the choice for world class engineering integration. Though a whole lot of what those Catia systems are fed comes from Pro/E & Solidworks. |
You forgot Newport News Shipbuilding.
Islands also right. I can vouch for the fact that Catia systems are being fed from Pro/E. oops forgot the Porsche content....I just had some case work done on my 3.3L case. I had the squirters removed so I could install the larger 964 squirters. He said (Paul from Cyntex) there be should a slight interference fit. If it did'nt he could get larger dia squirters.... FYI. |
OK, Chris gets the prize. Chris, If you want a t-shirt, send me your address and it'll be on the way!
In response to the Pro-E comment; yes, many companies use multiple systems depending on compliancy issues, legacy data, economic considerations, capability and user preference. I can guarentee you that Porsche does not "feed" CATIA data from Pro-E. There are immense benefits to be gained from staying with an integrated software tool but that is a whole new discussion not appropriate for this forum. Again, any new info on squirters is greatly appreciated! JB |
Yeh for a mechancial engineer maybe. But for the more trival mechanical problems that an EE does its ACAD because you can't find any design drafters that can use anything else. For the EE (and thats microwave and RF)stuff I own my own copy of ADS (Formally HP series IV). In any case mechanical desktop is good nuff for the squirter problem.
i would just try to find a later case with factory squirters from Porsche, I think every case after the 2.2 had them, they are like
50 bucks on ebay, then spec it. |
If I can really get one for 50 bucks, heck yes. I will try to.
| All times are GMT -8. The time now is 08:21 PM. |
