Banned
snowman's Avatar
Ultimate valve jobs
If you want the ultimate valve job check and see if your machinist has the following stuff.
And if your into alignment how about the latest Hunter stuff
Note the Aston Martin DB2 on the rack isn't mine, Darn.
And if you all are into resizing your connecting rods this is the cats ....
And finally if your into balancing everything this is as good as it gets.
And finally if you all are going to race any cute girls in a honda, and they have a Pink engine like this one, watch out.
Old 05-02-2003, 01:12 AM
Cool
Originally posted by Wayne at Pelican Parts
. Walt has an old-fashioned balancer with a strobe light.
-Wayne
I believe that a specific type of old fashioned balancer with a strobe light uses a better method of correcting imbalance than the new machines.. some variables can be corrected that the new style can't.. not a pro, only trying to remember.. maybe worth investigating.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-06-2003, 09:01 PM
Banned
snowman's Avatar
They both work the same way, only the electronic one displays the location and ammount of weight needed to balance the item. The electronic one uses more methods of balance than the other one, I think, not sure. In any case I suspect that they both balance as well as the other, but the newer electronic one is a whole lot more versitle and easier to use.
Old 05-06-2003, 09:25 PM
Banned
snowman's Avatar
PS sorry I forgot to tell how it works, It works by using an accelerometer attached to one end of the item being balanced. The accelerometer detects the angle and ammount of imbalance. the electronics performs calculations, trasnparent to the user, and tells where and how much is needed to balance the item. IT can perform single plane, and dual plane balancing, as well as static and dynamic balance.
Old 05-06-2003, 09:29 PM
