ARP rod bolts ground when balancing
My new rod bolts where ground when they balanced the engine. ??
Lyndon
I hope you didn't plan on using a stretch gauge. If it were me, I would be chosing another machine shop in the future.
I had to read them the riot act. They have now decided to replace them and grind of the appropriate amount that was taken from the bolts.
Lyndon |
Well that's a good response.
I am my 911's PO
What about removing material from the rod cap rib? Is that correct practice?
Not when the bolts are in the way .
I am my 911's PO
My point was that the rib on the rod cap is there for strength and should not be ground away for balancing. The shop needs to replace the rods, too.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
I agree with '78 SC.
Additional information Rod balancing - where to remove material
