barometric cell MFI pump
Hi,
In the progress collecting parts to build 2.45 l engine(Henry Schmidt) I keep the option open to have a MFI instead of Webers. So did send my 2.2E pump to Germany for a check. One of the outcomes was the barometric cell was not functioning. As I planned (looking forward)to work, adjust and tune the MFI pump myself based on all the great info on this Forum I need to find this Barometric cell. So if anybody knows where I can buy one, please let me know! Thanks, Bart |
We have a few. I just need to figure out how to test them.
Hi Henry!
Just sent you a PM. Thanks, Bart |
Direct email is the best way to get my attention.
And because I get 200+ email a day, that method can be challenging as well. |
Hi Henry,
Again, thanks for responding. I really don't like you to go through all effort of testing..... (Maybe first question is what you asking for them.) As depending on that I can take the 'gamble' that it does work and do the testing here in the Lowllands!? Cheers, Bart p.s. Would this work....put the cell in a bigger seal bag with air. Close the bag and put a load(pressure with your hands) on the bag.....It does not need a lot. I guess the cell will work 2 way (higher and lower pressure) To achieve the lower air pressure one will need a bit more effort I guess . I also believe if the pressurizing works the cell is ok, right!? not sure if movement is visible by the eye... |
| All times are GMT -8. The time now is 03:25 AM. |
