-   -   2.7 CIS rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1092165-2-7-cis-rebuild.html)
niushork 04-28-2021 12:55 PM
2.7 CIS rebuild
So I had to strip down my engine and it is not looking good.
Attached some pictures of what was found so far.
Funny (or tragic) thing is that the car went through a top end job 4 years ago.
http://forums.pelicanparts.com/uploa...1619639443.jpg
http://forums.pelicanparts.com/uploa...1619639452.jpg
niushork 04-28-2021 12:59 PM
Tomorrow we are going into the Crankshaft...fear of the Dark! fear of the Dark!http://forums.pelicanparts.com/uploa...1619639803.jpg
niushork 04-28-2021 01:00 PM
http://forums.pelicanparts.com/uploa...1619639990.jpg
niushork 04-30-2021 02:21 AM
Has anyone here done the upgrades mentioned on the Wayne Dempsey article?
I'm referring to this article
https://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild2.htm
Thanks for your comments and contributions
psychoideas 05-13-2021 04:02 AM
Have you been inside the crank case yet?
I too, was thinking about the 964 cams and the piston upgrade. I wonder if you can do the cams first and then the pistons at a later date?
I already have SSI heat exchangers on it.
Interested to see what you find.
niushork 05-18-2021 02:48 PM
Hi yes, we open the crank case and thank god is all good there. Basically this was a poorly done valve job that turned ugly. Rocker arms not properly adjusted so most likely they eat up the cams.
Spoke to a very reputable 911 engine builder and he mentioned that the Wayne Dempsey article refers to a 3.0 engine and not a 2.7, different beasts. Suggested me to stick with the original cams but time them as the 74 Carrera (the 75s were timed different due to emission controls).
psychoideas 05-18-2021 05:47 PM
That's good news that inside is OK.
Alan L 05-19-2021 01:00 AM
Check the cam spray bars - you probably already have.
Alan
