-   -   So what do you think of this engine? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/109231-so-what-do-you-think-engine.html)
Wayne 962 05-03-2003 11:31 PM
Okay, I'm in need of an engine for my 914-6. The original engine that was in that car is the 2.7L engine that was featured in the engine book. This engine is currently sitting in our showroom. Hence I need another one for my sixer.
Here's what I'm thinking:
- Euro Carrera 3.0L case
- 2.7 liter crank/rods
- 3.0 cylinders replated with Nikasil
- JE 3.0 high compression pistons or 100mm 3.2 pistons
- Either 2.7 or some 3.2 933 Turbo airplane heads I have.
- TEC-3 engien management system with twin-plug capability.
This would be a short-stroke 3.2, high compression engine with the small flywheel end that would plug right into the 901.
Any thoughts?
-Wayne
TimT 05-04-2003 07:58 AM
Wayne that is going to be a "hold on to your hat" fun set up!!
As a comparison, I have a 914/6 with a 3.2
10.5:1 JE's
Web Cam 20/21
Weber 46's
Tall manifolds
This is coupled to a short geared 901 box (AFMSX), This uses a '70/71 pull flywheel (this uses a custom pull type shift fork set up).
You will need to get a heavy duty clutch and pressure plate, (my stock clutch slipped under load on the 3rd/4th/5th shift)
I use the centerforce 915 RSR clutch now.
Youll have a blast in a 914 with the power the engine your building will make..What size rubber do you have on the car?
Wayne 962 05-04-2003 10:36 AM
I will have nines in the back and sevens or eights in the front. I have stock 5 1/2s on there right now. The engine is first for the car - suspension and flares is next. This car hasn't really run since I founded Pelican more than five years ago. Needless to say, I'm getting antsy...
-Wayne
Chas911 05-04-2003 03:41 PM
That engine would probably make that car a kick to drive. Especially with a set of cams that would make power to about 7K
Wayne 962 05-04-2003 04:32 PM
I would probably run 'S' cams in it...
-Wayne
Chas911 05-04-2003 05:28 PM
Perfect
