-   -   Threaded Gallery Plugs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1092973-threaded-gallery-plugs.html)
drgouk 05-09-2021 05:07 AM
Im building a few 4.0 engines based on new 993 factory cases. As the customer wanted the cases fully deburred, I had to remove the factory gallery plugs for cleaning purpose, along with the piston squirters. Ive never been a big fan of pressed in galley plugs, So I went with something a bit more positive and threaded the case/spot faced for aluminum sealing washers. All threads are metric, M24,M22,M18, M14, aside from the small drillings, I went with 1/8NPT
Thought I'd share the way i approached this. Thanks
David Gouk
http://forums.pelicanparts.com/uploa...1620562008.jpg
http://forums.pelicanparts.com/uploa...1620562023.jpg
http://forums.pelicanparts.com/uploa...1620562050.jpg
Henry Schmidt 05-09-2021 05:13 AM
Very nice....I like your thinking.
nocarrier 05-09-2021 05:37 AM
Looks really clean.
Do you have any pictures of your fixture? It looks really well made.
dannobee 05-09-2021 05:48 AM
Very nice!
I've often thought about buying all of the tooling to use ORB plugs, but just never bothered to do it. I have the ones used to make fuel rails and such, but not the whole set.
Henry Schmidt 05-09-2021 06:01 AM
One question: how have you determined the plug depth (spring preload) on the pressure relief valve?
The factory plug had a specific spring perch, your plug would need to match that depth. I guess a simple spacer would work given proper attention is applied.
I guess my question: why replace that plug?
drgouk 05-09-2021 07:34 AM
Hi Henry, the only plugs that have been replaced are the pressed in aluminium galley plugs. I will be using the factory steel plugs on the relief valves to retain the correct spring tension.
drgouk 05-09-2021 07:35 AM
Originally Posted by nocarrier (Post 11325772)
Looks really clean.
I will take some pictures a little later and put them up. Thanks
Henry Schmidt 05-09-2021 09:50 AM
You're right..... I misinterpreted the bottom plug.
nocarrier 05-10-2021 04:06 AM
In regards to the plug in the last picture. Is it going to interfere with the fan or are you planning on notching the fan housing?
drgouk 05-10-2021 09:13 PM
Its close, but clears. I had the plugs made for me by speedflow is Australia. They have made a lot of oddball one off stuff for me for the Toyota engines that I do. The challenge is the intersecting oil feed to the Number 7 main, The plug slightly overlaps the hole, but a small radius of the drilling regains the lost area.
http://forums.pelicanparts.com/uploa...1620706346.jpg
http://forums.pelicanparts.com/uploa...1620706365.jpg
scootergt3 05-11-2021 10:38 AM
wont the main galley plug on the top front of the case interfere with the fan housing?
nocarrier 05-11-2021 10:58 AM
Very nice work. Thanks for showing your fixture. Looks like it is precision ground on all sides.
Your machine looks like a very nice mill. Is it a cnc/manual version? I just outfitted my knee mill with a centroid control.
Henry Schmidt 05-11-2021 12:55 PM
Good catch. Different case but same mounting fan parameters.
http://forums.pelicanparts.com/uploa...1620762757.jpg
http://forums.pelicanparts.com/uploa...1620762825.jpg
