Pilot bushing for 3.3 turbo with GT3 Crankshaft
I am stuck on what Pilot bearing to use in a 3.3 turbo with a gt3 crankshaft and stock turbo clutch. As the gt3 crankshaft does not haver holes to bolt the stock bushing in place I need an alternative.
Flywheel mounted pilot bearing.
So I need to use a 77 -79 flywheel?
It depends on the transmission you're running.
You can also drill the GT3 crank for bearing mounting. |
| All times are GMT -8. The time now is 01:43 AM. |
