-   -   Rockers for a 3.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1093715-rockers-3-2-a.html)
Lang911 05-18-2021 04:11 AM
Rockers for a 3.2
I’ve sorted through a pile of rockers and have found early and late style and most with a triangle sone with a B. My stock rockers are B. The new replacements, 2, are both wearing unevenly and will be machined or replaced with “B” if that makes sense. I have plenty to choose from. Is the delta version aftermarket?
Will install 964 cams, otherwise stock.
http://forums.pelicanparts.com/uploa...1621336175.jpg
Classic 911 05-18-2021 04:20 AM
Following
Determined 05-30-2021 08:58 AM
I believe the delta was factory, I have them in my Carrera engines. I believe long ago I read they were stronger than the earlier ones. Alex
Richey 06-03-2021 09:04 PM
I know new replacement rocker faces are not necessarily parallel with the bushing , new rockers should be refaced . From my experience very early engines used "B" rockers and '72 , '73 used the delta .
gled49 06-06-2021 08:32 AM
It’s my experience the the Delta & B rockers are later, like for large journal cams with a larger foot. Early rockers have a smaller foot and no markings.
