-   -   Rebuilding my hydraulic chain tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1094492-rebuilding-my-hydraulic-chain-tensioners.html)
Harpo 05-28-2021 03:05 AM
Good morning everyone,
Does anyone know the part number of the hydraulic chain tensioner rebuild kit?
Harpo 05-28-2021 03:25 AM
Jerry Woods tensioner upgrade
Is the hydraulic chain tensioner even needed if I'm going to add the Jerry Wood upgrade
Harpo 05-30-2021 03:56 AM
Hard to believe that no one makes oil pressure fed chain tensioners rebuild kits.
dannobee 05-30-2021 05:58 AM
I haven't seen one. And the little air bleeds at the top seem to always go missing somewhere inside the engine too. I've always just priced out another set for customers.
Walt Fricke 06-08-2021 10:25 PM
Nothing to rebuild on these. Not at all like the early ones. If the working piston looses its seal, the part is toast. No rings or O rings involved in this.
Disassembly of these beyond removing the piston part for some reason (like the JWE modification) is as likely to cause damage to one or more of its parts as it is to solve an issue.
jtsilverfox 06-28-2021 09:42 AM
Waldo,
And for which car/engine?
jt
