| AndrewCologne |
04-14-2023 11:45 PM |
Originally Posted by PeteKz
One other thing: Did you use base gaskets? If not, you can add one or two to decrease the CR slightly. Those copper base gaskets are about .004"/.1mm, if I recall correctly.
IIRC 0.25 mm and 0.5 mm. The 0.5 copper ones on the bottom of the cylinder will be used if the heads have been re surfaced by common 0.25 mm.
But if you simply add those gaskets so the full height of the cylinder head exceeds the factory length then you have to add gaskets to the key chain housing as well IIRC so the hole for the cam shaft in that housing is still properly aligned.
