Turbo oil pump sealant
Does anyone know this glue/sealant used on the pickup to case junction of the turbo oil pump?
Mine is cracking off, probably should replace before re-installation.
Old 01-15-2022, 12:13 PM
anyone?
Old 01-15-2022, 09:42 PM
I am my 911's PO
'78 SC's Avatar
Google this:
pick up tube epoxy siteelicanparts.com
Let us know what you decide.
Er, that's a colon between words site and pelicanparts.com
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 01-17-2022, 06:03 AM
I wouldn’t epoxy it until you placed it in the case for correct location.
Bruce
Old 01-17-2022, 06:09 AM
Thanks for your replies, as it is slightly loose i will remove it fully and replace the adhesive.
From what i can see it was originally fitted with a high temp epoxy resin type adhesive, JB is rated to 288DegC ( 560f ) so it should be comfortable enough to replace.
I see one guy also swaged it back in with some ball bearing and ramp contraption, I'll check it out when i clean it up, maybe its possible to do both.
I'll post some pictures when i do it.....and I'll probably remove the guts beforehand and do it with an empty case.
Old 01-17-2022, 07:40 AM
Bruce
I fully agree !!
Old 01-17-2022, 07:41 AM
I am my 911's PO
'78 SC's Avatar
If you disassemble the pump, mark the rotors and reassemble everything with the same engagement. Make sure it all turns freely.
Old 01-17-2022, 08:09 AM
Just disassembled, correct engagement noted! Thanks
Old 01-17-2022, 09:29 AM
Easy to dismantle, you can see all the epoxy residue.
Plan....remove old epoxy, re-plate the pickup tube along with the other 5 kilos of nuts and bolts and reassemble.
I will skim a couple of thou off the centre-plate just to clean it up also.
Apparently i have it on good authority from another source that it's JB-weld for the pick up and 6ft/lb with loctite 270 for the nuts/studs
Old 01-17-2022, 10:02 AM
I am my 911's PO
'78 SC's Avatar
I can't visualize exactly where you intend to remove material, but the clearances between the ends of the rotors and the case are very close. This is to prevent oil from by-passing and reducing pump performance. Anything that changes the overall case internal length will need corresponding corrections to the length of the rotors (or the interior of the case thickness), or the rotors may bind in the case.
Old 01-18-2022, 08:04 AM
Send it out to supertec to get it inspected, flowed, assembled
You have too much work into everything to have a pump in the bottom that won’t be the best and you have to start over.
Bruce
Old 01-18-2022, 08:15 AM
The centre plate is flat, what is critical is the dept of the cases that hold the rotors in relation to the length of the rotors themselves, I'm not touching these parts. Skimming the plate will just affect the overall length of the pump but by a negligible amount and as the shafts apertures are open it will not make any difference at all.
I've already got it back in the case without the internals in order to get the pick up bonded back to it's case.
Old 01-18-2022, 08:54 AM
Bruce
Thanks for your concern, i've got this!!
Old 01-18-2022, 08:55 AM
Puny Bird
Mark Henry's Avatar
I use Hysol Loctite 9340.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-18-2022, 01:50 PM
Thanks Mark, any particular reason?
Old 01-19-2022, 06:44 AM
Puny Bird
Mark Henry's Avatar
Because I have it, I've used it for years, it's high heat and a good epoxy for the job.
I don't surface the center, I do spec the halves/clearance and will surface them if needed. I inspect and/or replace the bushings. I also DFL coat the inner chambers, PITA to do it right as you have the mask them well.
Old 01-19-2022, 07:34 AM
Thanks Mark,
I have normal wear marks on pressure side but some heavier scoring on the other, will just clean it up.
I'm not junking a $1400 pump for a little scoring on the scavenge!!
Tell me, what are you using for DFL?
I've already re epoxy'd the tube using JB, i'm happy that the temperature performance is ok. I cleaned it up and degreased with MEK and then laid it in the case with the strainer for support, i'm happy with that.
After its properly cured i'll remove any excess inside the chamber before i rebuild.
Old 01-19-2022, 07:59 AM
Puny Bird
Mark Henry's Avatar
You have a 930 pump, I don't use the DFL (Dry Film Lube) on the steel half. I use Tec-Line DFL.
Old 01-19-2022, 08:11 AM
Does anyone know what the material is around the end of the dowel pins?
When the pump was removed the pins were migrated about 5 - 10 mm out of the case. They drifted them back in no problem but i wonder if there is some product that is supposed to be here?
Old 01-19-2022, 11:55 AM
Puny Bird
Mark Henry's Avatar
Likely a factory loctite type product, any loctite will work.
Old 01-19-2022, 12:58 PM
