Ideal big end bearing clearance
2.0l 1967 S std crank.
Runabout car.
20/50 oil warm climate.
I have a range of bearings to mix and match.
Where are the contempary thoughts.
Porsche have a huge range of dimensions.
Thanks lyndon
Old 08-24-2021, 01:17 AM
I'm only aware of one set of clearances as called for in the spec book
What are these others you mention?
Old 08-25-2021, 07:56 AM
It varies. Under a thou to 3.
Should I'm aim low or high.
Old 08-25-2021, 03:10 PM
clearance
I just sent you an intermediate shaft aluminum gear and perfect rod bearings.What you do is what I do.Measure your crank for rod journals.Install the new bearings in the rods and torque with old rod bolts.Use a bore gauge and check the size.Figure out the difference.You can make up the difference by machining the big end of the rod to get the correct clearance.Just need a good machinist.If you use ARP BOLTS it is different as the ARP Bolts are torqued at a higher rate of 50 lbs.which changes the big end dimension for clearance.If you are confused send me a message.Ciao Fred
Old 08-25-2021, 03:16 PM
Fred. With that system. Should I aim for a close or loose clearance ??
Lyndon
Old 08-25-2021, 03:34 PM
best clearance
If it was a high reving or high compression engine maybe a little looser.For a street car just follow factory specs.Their engineers will always be way smarter than I am.The specs are there for a reason as a guideline.Ciao Fred
Old 08-25-2021, 03:39 PM
So closer to 1 thou than 3 ?
Lyndon
Old 08-25-2021, 03:43 PM
Done
Crank back from a Polish.
I have.
.0025
.0022
.0024
.0021
.0022
.0024 thou.
I have 001" over size bearings to achieve this
Worthy of mention. STD Glyco bearings were absolutely spot on. 001" bigger clearance. I have no idea where they were made but the quality in clearance was perfect.
Lyndon
Old 08-26-2021, 12:27 AM
looks like you're right in the middle, I'd say good.
Old 08-26-2021, 06:41 AM
the spec
The Pauter rods will wake the the engine up.Your spec is good.Those rods make it feel like a lightened flywheel has been added.Also at 130mm rod length you are at a desired rate of almost 2 to 1 rod stroke ratio.All my short stroke 2.8 built on 3.0 turbo or 3.0 carrera have 132mm rod length.It softens the angle when then the piston skirt hits the cylinder and decreases wear and improves mid range torque.Look at BMW engines as there rod length is longer then the stroke.Hence more mid range torque.
Old 08-26-2021, 03:09 PM
Of interest.
My old rod bearings measured at .005" with one at .0045"
Lyndon
Old 08-26-2021, 03:12 PM
How many miles did the bearings have on them?
Old 08-26-2021, 07:14 PM
Have no idea
I think it's never been opened since 1966
Old 08-26-2021, 07:16 PM
Ingenieur
Curious if they removed the plugs from your crank to clean the oil passages after polishing. I do not normally have the plugs removed.
Originally Posted by Lyndon302 View Post
Done
I have.
.0025
.0022
.0024
.0021
.0022
.0024 thou.
Lyndon
Old 08-26-2021, 07:49 PM
Nope just linished
Old 08-26-2021, 07:50 PM
