Piston cleaning / 964 3.6
Been doing a lot of reading but a lot of threads seem to be unanswered.
964 3.6 motor and this is really the first time reusing pistons for me, and wondering about cleaning
I have two buckets of Berryman CHem-Dip here and wondering if that is okay on the pistons for a hour or so
Ive read oven cleaner, but can also damage piston, laquaer Thinner, simple green, wd40, acetone and transmission fluid mix, brake fluid, diesel fuel. the list goes on and on
Old 12-04-2019, 04:57 PM
If it's the newer water based stuff, you might have to let them sit overnight. If you still have the old strong stuff that takes the skin right off of your fingers, then an hour would probably work.
What I've found that works is Meguiars Chrome Wheel cleaner (in the red bottle), available at Wal-Mart or Target. Spray on, clean with an old toothbrush, then rinse off. The aluminum wheel cleaner works too but isn't anywhere near as strong.
Old 12-04-2019, 07:32 PM
Soda blasting is a nice way to get all the carbon off and out of the grooves..
Old 12-04-2019, 10:38 PM
I recently used aircraft stripper to remove a healthy layer of carbon from my pistons. Worked quite well.
Old 12-05-2019, 05:07 AM
Under the radar
Trackrash's Avatar
I always seem to have some old brake fluid around. Does a nice job of getting the carbon off.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-05-2019, 07:34 AM
targa72e's Avatar
berryman over night. Brush carbon off with brass wire brush. repeat as needed. Do no use wire brush on ring grooves. once carbon is removed from tops I use dish soap and warm water with a tooth brush to get the ring grooves clean. repeat until water says clean.
john
Old 12-05-2019, 11:15 AM
Wheel cleaner is an acid, I believe. John
Old 12-06-2019, 10:22 AM
Émilio
bender706's Avatar
We pass them in the cleaning machine
EP9 Autosport
Old 12-07-2019, 09:48 PM
Easily Confused
dtxscott's Avatar
Are the piston domes coated with anything like Alusil? Does the soda or bead blast remove it?
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 05-23-2021, 05:51 PM
safe's Avatar
I use an interior cleaner called SPAM.
Submerge the pistons for 1-2 hours, brush of with warm water and a nylon brush (almost not needed).
This piston was left over night, but that isn't needed.
Magnus
Old 06-02-2021, 02:55 AM
I was told to use oven cleaner. works even better if the pistons are hot( oven)
Old 06-03-2021, 09:38 AM
JoeMag's Avatar
Is the SPAM cleaner “Scholl SPAM Universal Cleaner”? ...that’s really amazing how well that did.
Old 06-04-2021, 11:24 AM
safe's Avatar
Yes, it is. Amazing is the word!
It works valves too, but on a really caked crusty exhaust valve its limited.
Magnus
Old 06-11-2021, 02:22 AM
