CE Ring Removal
I'm doing some cleaning on a 993 motor (first rebuild), what is the best method to remove the ce rings / cylinder head gaskets on top of the cylinders? I've been gently trying to use a pick but I am afraid I will mar/dent the edge of the groove. I've searched all over and have not found an answer, so I am guessing there is an easy solution!
Thanks for help in advance
Old 06-19-2021, 11:14 AM
