surge tank fuel pump need for ECU conversion
I'm considering an ECU conversion.
The design for modern ECU cars is an inside the fuel tank, fuel pump. Is this a design consideration for a 911 conversion??? Is the electrical noise from the Bosch -044 fuel pumps that bad???? How about the Bosch starter motors too???
1980 911 - Metzger 3.6L 2016 Cayman S |
Racer
You don’t have to use an in the tank fuel pump with a “modern” ECU. My race car uses a MoTec M130 ECU and a single external Bosch 044 fuel pump. My fuel cell has an internal surge tank too.
The Bosch 044 is not quiet but I never hear it unless my engine is shut off.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Puny Bird
Not sure on the 911 but my 914 the fuel tanks have a surge ring, sort of a can inside the tank that serves as a built in surge tank. For a hot street car and AX it's more than adequate, even racing it would only may become an issue if the tank was below a 1/4 full.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Good advice from the 2 above. Never have seen the need for other than a quality pump mounted in factory location with modern ECU conversions.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I will add this:
I have a duel pump config with an SC-style unit and an 044. They both sound like fuel pumps. They are sitting in the frunk and my 911 is a race car without any sound insulation. I don't think one is really any louder than the other, but in my application it does not matter. Be careful with sourcing 044s- there are likely counterfeit units in the supply chain.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
You don't need to change anything, your stock fuel pump will work just fine.
Yes, the 044 pump i loud!
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
It's a 914 ...
You can cut down on the noise from any fuel pump by using rubber cushioned mounts. Solid mounting transmits more vibration and makes the pump noisier.
