-   -   Ring gap for boost (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1097688-ring-gap-boost.html)
Tippy 07-12-2021 11:41 AM
Ring gap for boost
I'm fairly confident I didn't gap my rings enough the 1st time I rebuilt my engine (3.4 based 3.2) and tore up the Nikasil.
Boost is pretty addicting to me and I live in central Texas where temps get over 100 degrees - I'm leaning on a healthy gap this time.....
What gap would you guys do?
Per Wiseco, they are stating (for boosted race motors) around 0.006" times a 4.000" bore resulting in 0.024" total gap. I have 98mm/3.858" cylinders so should be close to this gap.
Another site is stating around 0.007-0.008" per inch of bore for E85 and high boost. That would be 0.027" to 0.031"
What would you do?
I rather go loose and have a tad more blowby than ever butt ends of the rings!!!
TIA
stownsen914 07-12-2021 08:45 PM
I'd assume the piston manufacturer should give you the best info. Make sure they know you're using plated aluminum cylinders.
Henry Schmidt 07-14-2021 02:42 PM
Manufacturer should get you close. The important thing to remember with boosted and high RPM engines is that the 2nd ring should have .004"-.008" additional gap.
The theory is that you want gasses trapped under the second ring to escape without pressuring the top ring.
Edit
HaroldMHedge 07-14-2021 07:15 PM
Henry,
Do you mean 0.004"-0.008" additional gap?
Harold
Henry Schmidt 07-15-2021 07:26 AM
Originally Posted by HaroldMHedge (Post 11392080)
Henry,
Harold
Sorry, you are correct .004"-.008"
Tippy 07-18-2021 12:12 PM
Thanks y'all, I set them to the high side of heavily boosted motors.
safe 07-21-2021 03:51 AM
Ah, so that is the reason! Thanks! :)
dkirk 07-31-2021 11:18 AM
What Henry states is also good advice for naturally aspirated engines. A slightly increased end gap on the second compression ring reduces oil consumption.
