-   -   Engine experts chime in please (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1098116-engine-experts-chime-please.html)
Harpo 08-05-2021 03:46 PM
Originally Posted by Lyndon302 (Post 11408157)
I will strip it down Monday.
It has timing chains that are linked. Also the pistons/ rings are not ideal. ( Was done at the peak of covid and I had to compromise )
This is a good excuse to part the case plus I have some goodies in the house.
Lyndonhttp://forums.pelicanparts.com/uploa...1627628595.jpg
Where did you get your straight cut gears? Brand?
Lyndon302 08-05-2021 04:12 PM
Jon at EBS
Pauter same as the the rods.
Lyndon
Lyndon302 08-06-2021 12:24 AM
Update
I'm sure now it's rod bearing that's in the filter.
They are worn. So I'm glad it's apart.
I will get the crank measured. Then I'm using ACL rod bearings. I can get STD. 001 over and 001 under in race spec. Locally made.
The right price as well. Speaking to the guys in Tassie they have made bearings ( one off which they don't supply ) for a mob in the USA.
So some Porsche parts in the USA are rebranded ACL.
http://forums.pelicanparts.com/uploa...1628234513.jpg
http://forums.pelicanparts.com/uploa...1628234513.jpghttp://forums.pelicanparts.com/uploa...1628234924.jpg
Lyndon302 08-06-2021 01:28 AM
http://forums.pelicanparts.com/uploa...1628238339.jpg
mikedsilva 08-06-2021 05:24 AM
ACL make great bearings.
BTW, your workspace is fantastic. Wish I had it.
Mike
Harpo 08-06-2021 07:41 AM
Originally Posted by Lyndon302 (Post 11414443)
Jon at EBS
Lyndon
Thanks, just ordered mine
blue911rsr 08-06-2021 04:43 PM
In a street car you might want to reconsider straight cut ims gears are quite
noisy
Prsh356 08-06-2021 05:55 PM
I saw the edge of that gear looks like it was rubbing on something could that be where the aluminum flakes came from ?
Lyndon302 08-06-2021 07:46 PM
noisy
Can't be noiser than the transaxle
Lyndon302 08-06-2021 10:03 PM
The gear is good. One tooth has been squeezed by something against the steel gear. Old issue. Definitely it's flakes from the big ends.
ahh911 08-10-2021 08:34 AM
Lyndon, are you still thinking it's flakes from the big ends? If the flakes are tough and metallic, do you unfortunately have the chips missing from the crank and bearing structure? The pictures you've shown seem to to show the rod bearings with some soft layers still intact, I think the worse area's show copper.
Phil
