Aluminium or Mag case- how do you tell?
Hello,
Can somebody tell me how to tell if a case is Alu or mag, engine number starts with 614 Thanks |
Engine type number is a good method. Using serial number, Typically, the 3rd digit is model year. So 1974... mag case.
Aluminium is not dark grey like magnesium.
Lyndon |
Put a photo up will tell you
Find a non important spot on the case, scrape some material off and light ,if it burns it’s a mag!
Here is my history of the early 911 engine case revision history:
https://www.early911sregistry.org/forums/showthread.php?63809-911-engine-case-Revisions The earliest aluminium cases (65-68) had the serial # facing the rear. Then the magnesium cases had the serial # facing to the right. Late in the Mg period there were a few Al cases with 7R but these were for the RSR, and a few RS; so very rare. The later aluminium cases from 1973 on, no longer had 901 prefix casting part #'s (below the oil return tubes) and instead had 911 or 930 prefixes. It literally takes seconds to tell the cases apart. |
DJ - don't you mean from '74 on? '74-77 were the mag case years for the street models, no?
First street 911 mag case was 1969. Porsche won some type of award for the casting of it.
Ah, right. Brain failure
put a drop of vinegar in a discrete area. Magnesium will bubble. Aluminum will not.
