-   -   Need input on oil coolers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1099307-need-input-oil-coolers.html)
Forssling 08-05-2021 02:22 AM
Hi All,
I need to buy a new oil cooler for my -71T. Need your help...
1) What is now the brand of the Porsche original oil coolers? (It is not BEHR from what I can see)
2) Are there any brands recommended apart from the above?
3) Anyone that had problems with fitment or performance of any brand?
Thanks for any input.
Jörgen Forssling
Gothenburg
SWEDEN
356911930 08-05-2021 11:03 AM
Engine oil cooler or front fender oil cooler?
Gianni at Pelican Parts 08-05-2021 11:39 AM
No complaints from Pelicans that have upgraded to the CSF Performance Oil Coolers, they recently released the upgraded fender oil cooler which fits like factory, they also have some single and dual pass oil coolers that mount in the front bumper.
Forssling 08-05-2021 11:22 PM
The -71T only has the engine oil cooler.
//Jörgen
Harpo 08-06-2021 05:23 AM
Have you considered a trombone oil cooler, they usually are cheap.
Forssling 08-06-2021 05:41 AM
I’m looking for an original setup.
Jörgen
Harpo 08-06-2021 06:55 AM
The trombone oil cooler was original on US SC and Euro used the 28 row brass oil cooler
Forssling 08-06-2021 07:14 AM
Mine is a 1971 911T. So it has the aluminum oil cooler on the engine.
Jörgen
Harpo 08-06-2021 09:21 AM
I'm referring to auxiliary oil coolers located in the front right wheel well which would be in addition to your cooler that is bolted to your engine
Forssling 08-06-2021 09:27 AM
I appreciate your efforts but adding a front oil cooler isn’t solving my problem. My engine oil cooler is leaking and I need to replace it. Please look at my initial post.
Jorgen
Harpo 08-06-2021 12:28 PM
oops, sorry
jpnovak 08-06-2021 12:38 PM
There are two types of engine oil coolers. The difference is how the oil line attaches. The early (71 and early) have a threaded fitting and that is the style you want. The 73-later have a "hose fitting" attachment for the "S" hose and will not be compatible with your early oil cooler.
Depending on where the leak is, you could have the original one welded/repaired.
I Have bought a few used coolers after pressure/leak testing with good results. Have not purchased any "new" ones.
Forssling 08-06-2021 01:11 PM
I have tested my (thread fitting) oil cooler and it has been deemed unrepairablle by a reputable firm. I don’t have the stamina to try a second hand one. Don’t want to risk to have to pull the engine again.
So it will be a new one. Porsche original or repro is what I’m trying to decide.
Thanks for all input!
Jorgen
HaroldMHedge 08-06-2021 07:49 PM
I used Google Europe and found an after market 901-107-041-03 oil cooler on partsworks.de.
partworks.de/en-en-en-en-en-partworks-de-porsche-911-f-65-73-3-engine-cooling-oil-cooler-engine-oil-for-porsche-911-f-t-e-s-2-0-2-2-912-1-6.html#&gid=1&pid=1 (add https:// to the beginning)
This cooler does not have the same zebra fin area and it appears to have less fin area especially from the bottom.
Pelican Engine Oil Cooler 901-107-041-03-OEM
Compare the photos closely.
I would buy an original Porsche cooler over the one offered by partworks.de.
ed mayo 08-07-2021 08:30 AM
I bought the European made aftermarket cooler from Stoddard 6 years ago. Perfect fit and no leaks. SIC 107 041 02. Expensive but worth it.
safe 08-10-2021 01:33 AM
Jorgen
You don't need to pull the engine, you just need to lower the rear of the engine some 1-2 inches, whatever the oil lines approve off :)
But a new one is a good choice unless you are 110% that a used has come of a healthy engine and has no debris in it.
