Piston squirter orifice size
Good afternoon everyone,
What size piston squirter do I want for a 3.5L? Compression is TBD but it will have a blueprinted 964 pump. At a minimum I was thinking about upgrading from 1.5 to 2.0mm Supposedly this is how they came from the factory Factory: 1.5mm Turbo: 2.0mm 964 & 993: 2.5mm Thanks David |
What oil pressure do they open at?
Good question, but I have no idea
[QUOTE=cgarr;11414916]What oil pressure do they open at?[/QUOTE
More oil and lower opening pressures can screw with other parts of the oil delivery system. What’s the point? |
| All times are GMT -8. The time now is 06:22 AM. |
